Episerver forms - Adding custom placeholder to placeholder dropdown
Greetings!
I need to add a placeholder option by code without creating a new element in the form container to the "Insert placeholder" functionallity that is used when composing emails in Episerver forms.
Whats the best way to go about this?
I have tried overriding
GetPredefinedPlaceHolderKeys()
I did this by creating a class that inherits from placeholdermanager and using the attribute below
[ServiceConfiguration(Lifecycle = ServiceInstanceScope.Singleton, ServiceType = typeof (IPlaceHolderManager))]
I also tried creating a [InitializableModule] that configures the IPlaceHolderManager interface to use my implementation of the PlaceHolderManager class. This works as i can stop my code and see that my implementation of the PlaceHolderManager is used. Yet no new options from my GetPredefinedPlaceHolderKeys() method.
Any help is much appreciated! :)
#158336
Sep 27, 2016 16:26
Hi Jonas! Im working with this problem aswell. Did you have any luck?
#171847
Nov 18, 2016 14:29
Hi, sorry for this late.
As described in the class comment, The PlaceHolder API is a pre-release API that is UNSTABLE (of API functions signature) and might not satisfy the compatibility requirements as denoted by its associated normal version.
It is considered as internally. This is the first time I have 2 questions about it.
So, please raise your need, elaborate your real usecase. We will try the best to make it stable in next release! (in 4.3 I think). I started a story  for it.
#171952
Edited, Nov 22, 2016 12:14
@THACH Lockevn
Thank you for your response. I have solved my problem with a different approach, Its good to know the API will be useful in a future version if i encounter the same task again :)
@yoloswagson
My problem was to add pageID of the page that sent the form as a placeholder. I solved this by code adding a hidden predefined element block on each new form created named PageID.
To recieve the pageID value for the hidden element block placeholder when a mail is sent i override the GetFormSubmissionActors in ActorsExecutingService and simply replace #PageID# with the value i want in the emailModel body.
This left me with the problem that when i export forms or view submissions in my forms mode a empty field named PageID lingers there.. lucky for me my client wanted the pageID in the exported forms and submissions aswell. But if you can hide the field somehow or maybe not save it to database on a submit then you should be all good.
Heads up tho i tried this quickly and it didnt find a solution instantly so it might require some digging :)
#171954
Nov 22, 2016 12:52
Update, Forms 4.3 have PlaceHolder API as BETA, and I think you can start using it.
More information is here http://world.episerver.com/documentation/developer-guides/forms/placeholder-api/
#174234
Edited, Jan 23, 2017 5:16
