Episerver CMS 9.12.2.0 - Error After Update
Guys,
Upgraded to Episerver CMS 9.12.2.0 and everything appears OK in the local but things get very strange in Azure. stuck with the below Exceptions. Pl suggest if this rings a bell
P.S - All Azure IP's are allowed to SQL Server & Connectionstrings looks good to me
InvalidOperationException: Invalid attempt to read when no data is present.]
   System.Data.SqlClient.SqlDataReader.CheckDataIsReady(Int32 columnIndex, Boolean allowPartiallyReadColumn, Boolean permitAsync, String methodName) +1661221
   System.Data.SqlClient.SqlDataReader.TryReadColumn(Int32 i, Boolean setTimeout, Boolean allowPartiallyReadColumn) +48
   System.Data.SqlClient.SqlDataReader.GetValueInternal(Int32 i) +31
   System.Data.SqlClient.SqlDataReader.GetValue(Int32 i) +73
   System.Data.SqlClient.SqlDataReader.get_Item(String name) +28
   EPiServer.DataAccess.ContentListDB.b__11_0() +111
   EPiServer.Data.Providers.<>c__DisplayClass28_0`1.b__0() +59
   EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +45
   EPiServer.Data.Providers.SqlDatabaseHandler.Execute(Func`1 action) +202
   EPiServer.DataAccess.ContentListDB.LoadDefaultSystemRoots() +61
   EPiServer.DataAbstraction.DefaultContentRootRepository.EnsureSystemRoots() +126
   EPiServer.DataAbstraction.DefaultContentRootRepository.Load(String rootName) +22
   EPiServer.DataAbstraction.DefaultContentRootService.Get(String rootName) +13
   EPiServer.Web.SystemDefinition.get_Current() +150
   System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) +0
   System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) +192
   System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +101
   EPiServer.ServiceLocation.<>c__DisplayClass0_0.b__0(IServiceLocator c) +23
   EPiServer.ServiceLocation.Internal.<>c__DisplayClass6_0.b__1(IServiceLocator s) +10
   lambda_method(Closure , IBuildSession , IContext ) +181
[StructureMapBuildException: Failure while building 'Lambda: Invoke(value(EPiServer.ServiceLocation.Internal.StructureMapConfiguredType+<>c__DisplayClass6_0).p, value(EPiServer.ServiceLocation.Internal.StructureMapConfiguredType)._serviceLocator)', check the inner exception for details
1.) Lambda: Invoke(value(EPiServer.ServiceLocation.Internal.StructureMapConfiguredType+<>c__DisplayClass6_0).p, value(EPiServer.ServiceLocation.Internal.StructureMapConfiguredType)._serviceLocator)
2.) Instance of EPiServer.Web.SystemDefinition (System.Object)
3.) new DependentContentTransfer(*Default of IContentLoader*, *Default of IContentTypeRepository*, *Default of IPermanentLinkMapper*, *Default of SiteDefinitionRepository*, *Default of SystemDefinition*)
4.) EPiServer.Core.Transfer.DependentContentTransfer
5.) Instance of EPiServer.Core.Transfer.IDependentContentTransfer (EPiServer.Core.Transfer.DependentContentTransfer)
6.) new PropertyContentReferenceListTransform(*Default of IPermanentLinkMapper*, *Default of IContentLoader*, *Default of IDependentContentTransfer*)
7.) EPiServer.Core.Transfer.PropertyContentReferenceListTransform
8.) Instance of EPiServer.Core.Transfer.PropertyContentReferenceListTransform
9.) Container.GetInstance(EPiServer.Core.Transfer.PropertyContentReferenceListTransform)
   lambda_method(Closure , IBuildSession , IContext ) +764
   StructureMap.Building.BuildPlan.Build(IBuildSession session, IContext context) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\Building\BuildPlan.cs:151
   StructureMap.BuildSession.BuildNewInSession(Type pluginType, Instance instance) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\BuildSession.cs:114
   StructureMap.Pipeline.NulloTransientCache.Get(Type pluginType, Instance instance, IBuildSession session) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\Pipeline\NulloTransientCache.cs:28
   StructureMap.BuildSession.ResolveFromLifecycle(Type pluginType, Instance instance) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\BuildSession.cs:103
   StructureMap.SessionCache.GetObject(Type pluginType, Instance instance, ILifecycle lifecycle) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\SessionCache.cs:93
   StructureMap.SessionCache.GetDefault(Type pluginType, IPipelineGraph pipelineGraph) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\SessionCache.cs:68
   StructureMap.Container.GetInstance(Type pluginType) in c:\BuildAgent\work\a395dbde6b793293\src\StructureMap\Container.cs:337
   EPiServer.ServiceLocation.StructureMapServiceLocator.DoGetInstance(Type serviceType, String key) +40
   EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance(Type serviceType, String key) +42
[ActivationException: Activation error occurred while trying to get instance of type PropertyContentReferenceListTransform, key ""]
   EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance(Type serviceType, String key) +101
   EPiServer.ServiceLocation.ServiceLocatorImplBase.GetInstance() +60
   EPiServer.Enterprise.EnterpriseInitialization.Initialize(InitializationEngine context) +113
   EPiServer.Framework.Initialization.Internal.<>c__DisplayClass3_0.b__0() +19
   EPiServer.Framework.Initialization.Internal.ModuleNode.Execute(Action a, String key) +52
   EPiServer.Framework.Initialization.Internal.ModuleNode.Initialize(InitializationEngine context) +80
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +245
[InitializationException: Initialize action failed for Initialize on class EPiServer.Enterprise.EnterpriseInitialization, EPiServer.Enterprise, Version=9.12.2.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7]
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +588
   EPiServer.Framework.Initialization.InitializationEngine.ExecuteTransition(Boolean continueTransitions) +114
   EPiServer.Framework.Initialization.InitializationEngine.Initialize() +32
   EPiServer.Framework.Initialization.<>c.b__7_0(InitializationEngine e) +9
   EPiServer.Framework.Initialization.InitializationModule.EngineExecute(HostType hostType, Action`1 engineAction) +365
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +170
   EPiServer.Global..ctor() +76
   WebApplication.EPiServerApplication..ctor() +42
   ASP.global_asax..ctor() in c:\Users\rajkumarb\AppData\Local\Temp\Temporary ASP.NET Files\root\89cde6bf\d9f496d1\App_global.asax.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +113
   System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +206
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +83
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1065
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +124
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +20
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +60
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +263
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9946132
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +90
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +261
#157809
Edited, Sep 22, 2016 14:48
Maybe an database upgrade of the Epi db is missing on azure? Just guessing though mind you. I don't recognize that particular error.
#157817
Edited, Sep 22, 2016 17:09
<p>Where do i find the latest DB Scripts ?</p>
#157818
Sep 22, 2016 17:11
I think they were inside Framework nuget package or CMS.Core package. You can also set flag in configuration (episerver.framework section) to automatically update database. But I guess - if Db would be guilty, high chances are that you should actually receive different exception..
#157843
Sep 22, 2016 23:43
Usually complains about version of db yes so it's a long shot :)
#157845
Sep 23, 2016 7:40
Looks like I see enough reasons to believe that this is indeed my database issue .. Apparently the DACPAC created out of the Episerver.cms.core.sql file by Visual Studio (that i need to automate the deployment process) has now ignored the INSERT statements
-- EPiServer.Cms.Core database script--
--beginvalidatingquery
    if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[sp_DatabaseVersion]') and OBJECTPROPERTY(id, N'IsProcedure') = 1)
        select 0, 'The episerver cms core database is already installed'
    else
        select 1, 'Ok'
--endvalidatingquery
GO
PRINT N'Creating [dbo].[LongParameterTable]...';
GO
PRINT N'Creating [dbo].[editDeletePageInternalTable]...';
GO
PRINT N'Creating [dbo].[BigTableDeleteItemInternalTable]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_DateTimeOffset]...';
GO
PRINT N'Creating [dbo].[HostDefinitionTable]...';
GO
PRINT N'Creating [dbo].[StringParameterTable]...';
GO
PRINT N'Creating [dbo].[UriPartsTable]...';
GO
PRINT N'Creating [dbo].[ContentReferenceTable]...';
GO
PRINT N'Creating [dbo].[IDTable]...';
GO
PRINT N'Creating [dbo].[ProjectItemTable]...';
GO
PRINT N'Creating [dbo].[ProjectMemberTable]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationStringTable]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationIntTable]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationGuidTable]...';
GO
PRINT N'Creating [dbo].[GuidParameterTable]...';
GO
PRINT N'Creating [dbo].[tblNotificationSubscription]...';
GO
PRINT N'Creating [dbo].[tblNotificationSubscription].[IDX_tblNotificationSubscription_UserName]...';
GO
PRINT N'Creating [dbo].[tblNotificationSubscription].[IDX_tblNotificationSubscription_SubscriptionKey]...';
GO
PRINT N'Creating [dbo].[tblIndexRequestLog]...';
GO
PRINT N'Creating [dbo].[tblIndexRequestLog].[IDX_tblIndexRequestLog_StoreName]...';
GO
PRINT N'Creating [dbo].[tblIndexRequestLog].[IDX_tblIndexRequestLog_Indexed_DateTime01]...';
GO
PRINT N'Creating [dbo].[tblIndexRequestLog].[IDX_tblIndexRequestLog_Indexed_String01]...';
GO
PRINT N'Creating [dbo].[tblNotificationMessage]...';
GO
PRINT N'Creating [dbo].[tblNotificationMessage].[IDX_tblNotificationMessage_SendAt]...';
GO
PRINT N'Creating [dbo].[tblNotificationMessage].[IDX_tblNotificationMessage_Sent]...';
GO
PRINT N'Creating [dbo].[tblNotificationMessage].[IDX_tblNotificationMessage_Read]...';
GO
PRINT N'Creating [dbo].[tblHostDefinition]...';
GO
PRINT N'Creating [dbo].[tblHostDefinition].[IX_tblHostDefinition_fkID]...';
GO
PRINT N'Creating [dbo].[tblSiteDefinition]...';
GO
PRINT N'Creating [dbo].[tblSiteDefinition].[IX_tblSiteDefinition_UniqueId]...';
GO
PRINT N'Creating [dbo].[tblActivityLogComment]...';
GO
PRINT N'Creating [dbo].[tblActivityLogComment].[IDX_tblActivityLogComment_EntryId]...';
GO
PRINT N'Creating [dbo].[tblActivityLogAssociation]...';
GO
PRINT N'Creating [dbo].[tblActivityLogAssociation].[IDX_tblActivityLogAssociation_From]...';
GO
PRINT N'Creating [dbo].[tblActivityLogAssociation].[IDX_tblActivityLogAssociation_To]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation].[IDX_tblTaskInformation_StoreName]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation].[IDX_tblTaskInformation_Indexed_Integer01]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation].[IDX_tblTaskInformation_Indexed_DateTime01]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation].[IDX_tblTaskInformation_Indexed_DateTime02]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation].[IDX_tblTaskInformation_Indexed_Guid01]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation].[IDX_tblTaskInformation_Indexed_String01]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation].[IDX_tblTaskInformation_Indexed_String02]...';
GO
PRINT N'Creating [dbo].[tblMappedIdentity]...';
GO
PRINT N'Creating [dbo].[tblMappedIdentity].[IDX_tblMappedIdentity_ProviderUniqueId]...';
GO
PRINT N'Creating [dbo].[tblMappedIdentity].[IDX_tblMappedIdentity_Provider]...';
GO
PRINT N'Creating [dbo].[tblMappedIdentity].[IDX_tblMappedIdentity_ContentGuid]...';
GO
PRINT N'Creating [dbo].[tblMappedIdentity].[IDX_tblMappedIdentity_ExternalId]...';
GO
PRINT N'Creating [dbo].[tblProjectMember]...';
GO
PRINT N'Creating [dbo].[tblProjectMember].[IX_tblProjectMember_fkProjectID]...';
GO
PRINT N'Creating [dbo].[tblProjectItem]...';
GO
PRINT N'Creating [dbo].[tblProjectItem].[IX_tblProjectItem_ContentLink]...';
GO
PRINT N'Creating [dbo].[tblProjectItem].[IX_tblProjectItem_fkProjectID]...';
GO
PRINT N'Creating [dbo].[tblProject]...';
GO
PRINT N'Creating [dbo].[tblProject].[IX_tblProject_StatusName]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_StoreName]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Boolean01]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Integer01]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Integer02]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Integer03]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Long01]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Long02]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_DateTime01]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Guid01]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Float01]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Float02]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Float03]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_String01]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_String02]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_String03]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic].[IDX_tblVisitorGroupStatistic_Indexed_Binary01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_StoreName]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Boolean01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Integer01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Integer02]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Integer03]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Long01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Long02]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_DateTime01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Guid01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Float01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Float02]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Float03]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Decimal01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_String01]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_String02]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_String03]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable].[IDX_tblSystemBigTable_Indexed_Binary01]...';
GO
PRINT N'Creating [dbo].[tblEntityType]...';
GO
PRINT N'Creating [dbo].[tblEntityGuid]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationQueuedString]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationQueuedString].[IDX_tblChangeNotificationQueuedString]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationQueuedInt]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationQueuedInt].[IDX_tblChangeNotificationQueuedInt]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationQueuedGuid]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationQueuedGuid].[IDX_tblChangeNotificationQueuedGuid]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationProcessor]...';
GO
PRINT N'Creating [dbo].[tblChangeNotificationConnection]...';
GO
PRINT N'Creating [dbo].[tblBigTableStoreInfo]...';
GO
PRINT N'Creating [dbo].[tblBigTableStoreConfig]...';
GO
PRINT N'Creating [dbo].[tblBigTableStoreConfig].[IDX_tblBigTableStoreConfig_StoreName]...';
GO
PRINT N'Creating [dbo].[tblBigTableReference]...';
GO
PRINT N'Creating [dbo].[tblBigTableReference].[IDX_tblBigTableReference_RefIdValue]...';
GO
PRINT N'Creating [dbo].[tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[tblBigTableIdentity].[IDX_tblBigTableIdentity_Guid]...';
GO
PRINT N'Creating [dbo].[tblBigTable]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_StoreName]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Boolean01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Integer01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Integer02]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Integer03]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Long01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Long02]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_DateTime01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Guid01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Float01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Float02]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Float03]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Decimal01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_String01]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_String02]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_String03]...';
GO
PRINT N'Creating [dbo].[tblBigTable].[IDX_tblBigTable_Indexed_Binary01]...';
GO
PRINT N'Creating [dbo].[tblXFormData]...';
GO
PRINT N'Creating [dbo].[tblXFormData].[IDX_tblXFormData_String01]...';
GO
PRINT N'Creating [dbo].[tblXFormData].[IDX_tblXFormData_String02]...';
GO
PRINT N'Creating [dbo].[tblXFormData].[IDX_tblXFormData_String03]...';
GO
PRINT N'Creating [dbo].[tblActivityLog]...';
GO
PRINT N'Creating [dbo].[tblActivityLog].[IDX_tblActivityLog_ChangeDate]...';
GO
PRINT N'Creating [dbo].[tblActivityLog].[IDX_tblActivityLog_Pkid_ChangeDate]...';
GO
PRINT N'Creating [dbo].[tblActivityLog].[IDX_tblActivityLog_RelatedItem]...';
GO
PRINT N'Creating [dbo].[tblSiteConfig]...';
GO
PRINT N'Creating [dbo].[tblSiteConfig].[IX_tblSiteConfig]...';
GO
PRINT N'Creating [dbo].[tblSynchedUserRelations]...';
GO
PRINT N'Creating [dbo].[tblSynchedUserRole]...';
GO
PRINT N'Creating [dbo].[tblSynchedUserRole].[IX_tblSynchedUserRole_Unique]...';
GO
PRINT N'Creating [dbo].[tblSynchedUser]...';
GO
PRINT N'Creating [dbo].[tblSynchedUser].[IX_tblWindowsUser_Unique]...';
GO
PRINT N'Creating [dbo].[tblSynchedUser].[IX_tblWindowsUser_Email]...';
GO
PRINT N'Creating [dbo].[tblSynchedUser].[IX_tblWindowsUser_LoweredGivenName]...';
GO
PRINT N'Creating [dbo].[tblSynchedUser].[IX_tblWindowsUser_LoweredSurname]...';
GO
PRINT N'Creating [dbo].[tblUniqueSequence]...';
GO
PRINT N'Creating [dbo].[tblLanguageBranch]...';
GO
PRINT N'Creating [dbo].[tblContentLanguageSetting]...';
GO
PRINT N'Creating [dbo].[tblContentLanguage]...';
GO
PRINT N'Creating [dbo].[tblContentLanguage].[IDX_tblContentLanguage_ContentGUID]...';
GO
PRINT N'Creating [dbo].[tblContentLanguage].[IDX_tblContentLanguage_Name]...';
GO
PRINT N'Creating [dbo].[tblContentLanguage].[IDX_tblContentLanguage_ExternalURL]...';
GO
PRINT N'Creating [dbo].[tblContentLanguage].[IDX_tblContentLanguage_URLSegment]...';
GO
PRINT N'Creating [dbo].[tblContentLanguage].[IDX_tblContentLanguage_ContentLinkGUID]...';
GO
PRINT N'Creating [dbo].[tblContentLanguage].[IDX_tblContentLanguage_Version]...';
GO
PRINT N'Creating [dbo].[tblWorkContentProperty]...';
GO
PRINT N'Creating [dbo].[tblWorkContentProperty].[IX_tblWorkContentProperty_fkWorkContentID]...';
GO
PRINT N'Creating [dbo].[tblWorkContentProperty].[IDX_tblWorkContentProperty_ContentLink]...';
GO
PRINT N'Creating [dbo].[tblWorkContentProperty].[IDX_tblWorkContentProperty_ScopeName]...';
GO
PRINT N'Creating [dbo].[tblWorkContentProperty].[IDX_tblWorkContentProperty_ContentTypeID]...';
GO
PRINT N'Creating [dbo].[tblWorkContentProperty].[IDX_tblWorkContentProperty_fkPropertyDefinitionID]...';
GO
PRINT N'Creating [dbo].[tblWorkContentProperty].[IX_tblWorkContentProperty_guid]...';
GO
PRINT N'Creating [dbo].[tblWorkContent]...';
GO
PRINT N'Creating [dbo].[tblWorkContent].[IDX_tblWorkContent_fkContentID]...';
GO
PRINT N'Creating [dbo].[tblWorkContent].[IDX_tblWorkContent_ChangedByName]...';
GO
PRINT N'Creating [dbo].[tblWorkContent].[IDX_tblWorkContent_StatusFields]...';
GO
PRINT N'Creating [dbo].[tblWorkContent].[IDX_tblWorkContent_ArchiveContentGUID]...';
GO
PRINT N'Creating [dbo].[tblWorkContent].[IDX_tblWorkContent_ContentLinkGUID]...';
GO
PRINT N'Creating [dbo].[tblWorkContent].[IDX_tblWorkContent_fkMasterVersionID]...';
GO
PRINT N'Creating [dbo].[tblWorkContentCategory]...';
GO
PRINT N'Creating [dbo].[tblWorkContentCategory].[IDX_tblWorkContentCategory_fkWorkContentID]...';
GO
PRINT N'Creating [dbo].[tblTree]...';
GO
PRINT N'Creating [dbo].[tblTree].[IDX_tblTree_fkChildID]...';
GO
PRINT N'Creating [dbo].[tblTask]...';
GO
PRINT N'Creating [dbo].[tblScheduledItemLog]...';
GO
PRINT N'Creating [dbo].[tblScheduledItem]...';
GO
PRINT N'Creating [dbo].[tblRemoteSite]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinitionDefault]...';
GO
PRINT N'Creating [dbo].[tblContentProperty]...';
GO
PRINT N'Creating [dbo].[tblContentProperty].[IDX_tblContentProperty_fkContentID]...';
GO
PRINT N'Creating [dbo].[tblContentProperty].[IDX_tblContentProperty_fkPropertyDefinitionID]...';
GO
PRINT N'Creating [dbo].[tblContentProperty].[IDX_tblContentProperty_ScopeName]...';
GO
PRINT N'Creating [dbo].[tblContentProperty].[IDX_tblContentProperty_ContentLink]...';
GO
PRINT N'Creating [dbo].[tblContentProperty].[IDX_tblContentProperty_ContentTypeID]...';
GO
PRINT N'Creating [dbo].[tblContentProperty].[IX_tblContentProperty_guid]...';
GO
PRINT N'Creating [dbo].[tblPlugIn]...';
GO
PRINT N'Creating [dbo].[tblUserPermission]...';
GO
PRINT N'Creating [dbo].[tblUserPermission].[IX_tblUserPermission_Permission_GroupName]...';
GO
PRINT N'Creating [dbo].[tblContentTypeToContentType]...';
GO
PRINT N'Creating [dbo].[tblContentTypeDefault]...';
GO
PRINT N'Creating [dbo].[tblContentType]...';
GO
PRINT N'Creating [dbo].[tblContentType].[IDX_tblContentType_ContentTypeGUID]...';
GO
PRINT N'Creating [dbo].[tblContentType].[IDX_tblContentType_Name]...';
GO
PRINT N'Creating [dbo].[tblContentSoftlink]...';
GO
PRINT N'Creating [dbo].[tblContentSoftlink].[IDX_tblContentSoftlink_fkContentID]...';
GO
PRINT N'Creating [dbo].[tblContentSoftlink].[IDX_tblContentSoftlink_fkReferencedContentGUID]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinitionType]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinitionGroup]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinition]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinition].[IDX_tblPropertyDefinition_ContentTypeAndName]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinition].[IDX_tblPropertyDefinition_fkContentTypeID]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinition].[IDX_tblPropertyDefinition_Name]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefinition].[IDX_tblPropertyDefinition_fkPropertyDefinitionTypeID]...';
GO
PRINT N'Creating [dbo].[tblContent]...';
GO
PRINT N'Creating [dbo].[tblContent].[IDX_tblContent_fkParentID]...';
GO
PRINT N'Creating [dbo].[tblContent].[IDX_tblContent_ContentGUID]...';
GO
PRINT N'Creating [dbo].[tblContent].[IDX_tblContent_ContentType]...';
GO
PRINT N'Creating [dbo].[tblContent].[IDX_tblContent_ArchiveContentGUID]...';
GO
PRINT N'Creating [dbo].[tblContent].[IDX_tblContent_ContentPath]...';
GO
PRINT N'Creating [dbo].[tblContent].[IDX_tblContent_fkContentTypeID]...';
GO
PRINT N'Creating [dbo].[tblFrame]...';
GO
PRINT N'Creating [dbo].[tblContentCategory]...';
GO
PRINT N'Creating [dbo].[tblContentCategory].[IDX_tblContentCategory_fkContentID]...';
GO
PRINT N'Creating [dbo].[tblContentCategory].[IDX_tblContentCategory_fkCategoryID]...';
GO
PRINT N'Creating [dbo].[tblCategory]...';
GO
PRINT N'Creating [dbo].[tblContentAccess]...';
GO
PRINT N'Creating unnamed constraint on [dbo].[tblNotificationSubscription]...';
GO
PRINT N'Creating [dbo].[[tblIndexRequestLog_Row]...';
GO
PRINT N'Creating unnamed constraint on [dbo].[tblHostDefinition]...';
GO
PRINT N'Creating [dbo].[tblTaskInformation_Row]...';
GO
PRINT N'Creating [dbo].[DF_tblMappedIdentity_ContentGuid]...';
GO
PRINT N'Creating [dbo].[tblVisitorGroupStatistic_Row]...';
GO
PRINT N'Creating [dbo].[tblSystemBigTable_Row]...';
GO
PRINT N'Creating unnamed constraint on [dbo].[tblBigTableStoreConfig]...';
GO
PRINT N'Creating [dbo].[tblBigTableReference_Index]...';
GO
PRINT N'Creating [dbo].[DF_tblBigTableIdentity_Guid]...';
GO
PRINT N'Creating [dbo].[DF_tblBigTable_Row]...';
GO
PRINT N'Creating [dbo].[DF_tblXFormData_Row]...';
GO
PRINT N'Creating [dbo].[DF_tblActivityLog_Action]...';
GO
PRINT N'Creating unnamed constraint on [dbo].[tblActivityLog]...';
GO
PRINT N'Creating unnamed constraint on [dbo].[tblSynchedUserRole]...';
GO
PRINT N'Creating [dbo].[DF__tblUniqueSequence__LastValue]...';
GO
PRINT N'Creating [dbo].[DF__tblLanguageBranch__Enabled]...';
GO
PRINT N'Creating [dbo].[DF__tblConten__Activ__51300E55]...';
GO
PRINT N'Creating [dbo].[DF__tblContentLanguage__ContentGUID]...';
GO
PRINT N'Creating [dbo].[DF__tblContentLanguage__Automatic]...';
GO
PRINT N'Creating [dbo].[DF__tblContentLanguage__FetchData]...';
GO
PRINT N'Creating unnamed constraint on [dbo].[tblContentLanguage]...';
GO
PRINT N'Creating [dbo].[DF__tblWorkContentProperty_guid]...';
GO
PRINT N'Creating [dbo].[DF__tblWorkPr__Boole__55209ACA]...';
GO
PRINT N'Creating [dbo].[DF__tblWorkPa__LinkT__48BAC3E5]...';
GO
PRINT N'Creating [dbo].[DF__tblWorkPa__Child__4B973090]...';
GO
PRINT N'Creating [dbo].[DF__tblWorkPa__PeerO__4C8B54C9]...';
GO
PRINT N'Creating [dbo].[DF__tblWorkPa__Chang__4E739D3B]...';
GO
PRINT N'Creating [dbo].[DF__tblWorkPa__fkLan__4258C320]...';
GO
PRINT N'Creating [dbo].[DF_tblWorkContent_CommonDraft]...';
GO
PRINT N'Creating unnamed constraint on [dbo].[tblWorkContent]...';
GO
PRINT N'Creating [dbo].[DF_tblWorkContentCategory_CategoryType]...';
GO
PRINT N'Creating [dbo].[DF_tblTask_Status]...';
GO
PRINT N'Creating [dbo].[DF__tblSchedul__pkID__1A34DF26]...';
GO
PRINT N'Creating [dbo].[DF_tblScheduledItem_Enabled]...';
GO
PRINT N'Creating [dbo].[DF__tblScheduledItem__IsRunnning]...';
GO
PRINT N'Creating [dbo].[DF_tblRemoteSite_IsTrusted]...';
GO
PRINT N'Creating [dbo].[DF_tblRemoteSite_AllowUrlLookup]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefault_Boolean]...';
GO
PRINT N'Creating [dbo].[DF__tblProper__fkLan__29B609E9]...';
GO
PRINT N'Creating [dbo].[DF__tblPropert__guid__43F60EC8]...';
GO
PRINT N'Creating [dbo].[DF__tblProper__Boole__44EA3301]...';
GO
PRINT N'Creating [dbo].[DF_tblPlugIn_Enabled]...';
GO
PRINT N'Creating [dbo].[DF_tblUserPermission_IsRole]...';
GO
PRINT N'Creating [dbo].[DF_tblContentTypeToContentType_Access]...';
GO
PRINT N'Creating [dbo].[DF_tblContentTypeToContentType_Availability]...';
GO
PRINT N'Creating [dbo].[DF_tblContentTypeDefault_VisibleInMenu]...';
GO
PRINT N'Creating [dbo].[DF_tblContentTypeDefault_ChildOrderRule]...';
GO
PRINT N'Creating [dbo].[DF_tblContentTypeDefault_PeerOrder]...';
GO
PRINT N'Creating [dbo].[DF_tblContentType_ContentTypeGUID]...';
GO
PRINT N'Creating [dbo].[DF_tblContentType_MetaDataInherit]...';
GO
PRINT N'Creating [dbo].[DF_tblContentType_MetaDataDefault]...';
GO
PRINT N'Creating [dbo].[DF_tblContentType_ContentType]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinitionGroup_SystemGroup]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinitionGroup_Access]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinitionGroup_DefaultVisible]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinitionGroup_GroupOrder]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinition_DefaultValueType]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinition_LongStringSettings]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinition_CommonLang]...';
GO
PRINT N'Creating [dbo].[DF_tblPropertyDefinition_ExistsOnModel]...';
GO
PRINT N'Creating [dbo].[DF__tblContent__ContentGUID]...';
GO
PRINT N'Creating [dbo].[DF__tblContent__Visible__2E06CDA9]...';
GO
PRINT N'Creating [dbo].[DF__tblContent__Deleted__2EFAF1E2]...';
GO
PRINT N'Creating [dbo].[DF__tblContent__ChildOr__35A7EF71]...';
GO
PRINT N'Creating [dbo].[DF__tblContent__PeerOrd__369C13AA]...';
GO
PRINT N'Creating [dbo].[DF__tblContent__fkMasterLangaugeBranchID]...';
GO
PRINT N'Creating [dbo].[DF_tblContent_ContentType]...';
GO
PRINT N'Creating [dbo].[DF_tblContent_IsLeafNode]...';
GO
PRINT N'Creating [dbo].[DF_tblFrame_SystemFrame]...';
GO
PRINT N'Creating [dbo].[DF_tblContentCategory_CategoryType]...';
GO
PRINT N'Creating [dbo].[DF_tblContentCategory_LanguageBranchID]...';
GO
PRINT N'Creating [dbo].[DF_tblCategory_CategoryGUID]...';
GO
PRINT N'Creating [dbo].[DF_tblCategory_PeerOrder]...';
GO
PRINT N'Creating [dbo].[DF_tblCategory_Available]...';
GO
PRINT N'Creating [dbo].[DF_tblCategory_Selectable]...';
GO
PRINT N'Creating [dbo].[DF_tblCategory_SuperCategory]...';
GO
PRINT N'Creating [dbo].[DF_tblAccess_IsRole]...';
GO
PRINT N'Creating [dbo].[FK_tblIndexRequestLog_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_tblHostDefinition_tblSiteDefinition]...';
GO
PRINT N'Creating [dbo].[FK_tblActivityLogComment_tblActivityLog]...';
GO
PRINT N'Creating [dbo].[FK_tblActivityLogAssociation_tblActivityLog]...';
GO
PRINT N'Creating [dbo].[FK_tblTaskInformation_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_tblProjectMember_tblProject]...';
GO
PRINT N'Creating [dbo].[FK_tblProjectItem_tblProject]...';
GO
PRINT N'Creating [dbo].[FK_tblVisitorGroupStatistic_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_tblSystemBigTable_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_ChangeNotification_ChangeNotificationString_ChangeNotificationConnection]...';
GO
PRINT N'Creating [dbo].[FK_ChangeNotification_ChangeNotificationString_ChangeNotificationProcessor]...';
GO
PRINT N'Creating [dbo].[FK_ChangeNotification_ChangeNotificationInt_ChangeNotificationConnection]...';
GO
PRINT N'Creating [dbo].[FK_ChangeNotification_ChangeNotificationInt_ChangeNotificationProcessor]...';
GO
PRINT N'Creating [dbo].[FK_ChangeNotification_ChangeNotificationGuid_ChangeNotificationConnection]...';
GO
PRINT N'Creating [dbo].[FK_ChangeNotification_ChangeNotificationGuid_ChangeNotificationProcessor]...';
GO
PRINT N'Creating [dbo].[FK_ChangeNotificationConnection_ChangeNotificationProcessor]...';
GO
PRINT N'Creating [dbo].[FK_tblBigTableStoreInfo_tblBigTableStoreConfig]...';
GO
PRINT N'Creating [dbo].[FK_tblBigTableReference_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_tblBigTableReference_RefId_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_tblBigTable_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_tblXFormData_tblBigTableIdentity]...';
GO
PRINT N'Creating [dbo].[FK_tblSynchedUserRelations_Group]...';
GO
PRINT N'Creating [dbo].[FK_tblSyncheduserRelations_User]...';
GO
PRINT N'Creating [dbo].[FK_tblContentLanguageSetting_tblContent]...';
GO
PRINT N'Creating [dbo].[FK_tblContentLanguageSetting_tblLanguageBranch1]...';
GO
PRINT N'Creating [dbo].[FK_tblContentLanguageSetting_tblLanguageBranch2]...';
GO
PRINT N'Creating [dbo].[FK_tblContentLanguage_tblWorkContent]...';
GO
PRINT N'Creating [dbo].[FK_tblContentLanguage_tblFrame]...';
GO
PRINT N'Creating [dbo].[FK_tblContentLanguage_tblContent2]...';
GO
PRINT N'Creating [dbo].[FK_tblContentLanguage_tblLanguageBranch]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContentProperty_tblContent]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContentProperty_tblPropertyDefinition]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContentProperty_tblContentType]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContentProperty_tblWorkContent]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContent_tblFrame]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContent_tblContent]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContent_tblWorkContent2]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContent_tblLanguageBranch]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContentCategory_tblCategory]...';
GO
PRINT N'Creating [dbo].[FK_tblWorkContentCategory_tblWorkContent]...';
GO
PRINT N'Creating [dbo].[FK_tblTask_tblPlugIn]...';
GO
PRINT N'Creating [dbo].[fk_tblScheduledItemLog_tblScheduledItem]...';
GO
PRINT N'Creating [dbo].[FK_tblContentProperty_tblContent]...';
GO
PRINT N'Creating [dbo].[FK_tblContentProperty_tblContent2]...';
GO
PRINT N'Creating [dbo].[FK_tblContentProperty_tblPropertyDefinition]...';
GO
PRINT N'Creating [dbo].[FK_tblContentProperty_tblLanguageBranch]...';
GO
PRINT N'Creating [dbo].[FK_tblContentTypeToContentType_tblContentType]...';
GO
PRINT N'Creating [dbo].[FK_tblContentTypeToContentType_tblContentType1]...';
GO
PRINT N'Creating [dbo].[FK_tblContentTypeDefault_tblContentType]...';
GO
PRINT N'Creating [dbo].[FK_tblContentSoftlink_tblContent]...';
GO
PRINT N'Creating [dbo].[FK_tblPropertyDefinition_tblContentType]...';
GO
PRINT N'Creating [dbo].[FK_tblContent_tblContent]...';
GO
PRINT N'Creating [dbo].[FK_tblContent_tblContentType]...';
GO
PRINT N'Creating [dbo].[FK_tblContent_tblLanguageBranch]...';
GO
PRINT N'Creating [dbo].[FK_tblContentCategory_tblCategory]...';
GO
PRINT N'Creating [dbo].[FK_tblContentCategory_tblContent]...';
GO
PRINT N'Creating [dbo].[FK_tblCategory_tblCategory]...';
GO
PRINT N'Creating [dbo].[FK_tblContentAccess_tblContent]...';
GO
PRINT N'Creating [dbo].[CH_tblIndexRequestLog]...';
GO
PRINT N'Creating [dbo].[CH_tblTaskInformation]...';
GO
PRINT N'Creating [dbo].[CH_tblVisitorGroupStatistic]...';
GO
PRINT N'Creating [dbo].[CH_tblSystemBigTable]...';
GO
PRINT N'Creating [dbo].[CK_ChangeNotificationProcessor_ChangeNotificationDataType]...';
GO
PRINT N'Creating [dbo].[CK_ChangeNotificationProcessor_ProcessorStatus]...';
GO
PRINT N'Creating [dbo].[CH_tblBigTableReference_Index]...';
GO
PRINT N'Creating [dbo].[CH_tblBigTable]...';
GO
PRINT N'Creating [dbo].[CH_tblXFormData]...';
GO
PRINT N'Creating [dbo].[CK_tblScheduledItem]...';
GO
PRINT N'Creating [dbo].[BigTableDateTimeSubtract]...';
GO
PRINT N'Creating [dbo].[netDateTimeSubtract]...';
GO
PRINT N'Creating [dbo].[ConvertScopeName]...';
GO
PRINT N'Creating [dbo].[GetScopedBlockProperties]...';
GO
PRINT N'Creating [dbo].[GetExistingScopesForDefinition]...';
GO
PRINT N'Creating [dbo].[tblWorkProperty]...';
GO
PRINT N'Creating [dbo].[tblPropertyDefault]...';
GO
PRINT N'Creating [dbo].[tblWorkCategory]...';
GO
PRINT N'Creating [dbo].[tblProperty]...';
GO
PRINT N'Creating [dbo].[tblPageLanguageSetting]...';
GO
PRINT N'Creating [dbo].[tblPageLanguage]...';
GO
PRINT N'Creating [dbo].[tblWorkPage]...';
GO
PRINT N'Creating [dbo].[tblPageTypeToPageType]...';
GO
PRINT N'Creating [dbo].[tblPageTypeDefault]...';
GO
PRINT N'Creating [dbo].[tblPageType]...';
GO
PRINT N'Creating [dbo].[tblPageDefinitionType]...';
GO
PRINT N'Creating [dbo].[tblPageDefinitionGroup]...';
GO
PRINT N'Creating [dbo].[tblPageDefinition]...';
GO
PRINT N'Creating [dbo].[tblPage]...';
GO
PRINT N'Creating [dbo].[tblCategoryPage]...';
GO
PRINT N'Creating [dbo].[netActivityLogCommentListMany]...';
GO
PRINT N'Creating [dbo].[netPlugInLoadByType]...';
GO
PRINT N'Creating [dbo].[netNotificationSubscriptionClearUser]...';
GO
PRINT N'Creating [dbo].[netNotificationSubscriptionClearSubscription]...';
GO
PRINT N'Creating [dbo].[netNotificationSubscriptionListSubscriptions]...';
GO
PRINT N'Creating [dbo].[netNotificationSubscriptionFindSubscribers]...';
GO
PRINT N'Creating [dbo].[netNotificationSubscriptionUnsubscribe]...';
GO
PRINT N'Creating [dbo].[netNotificationSubscriptionSubscribe]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_Finalize]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_RunBlocks]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_InitDateTimeOffsets]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_MakeTableBlocks]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_GetFieldNames]...';
GO
PRINT N'Creating [dbo].[sp_GetDateTimeKind]...';
GO
PRINT N'Creating [dbo].[netActivityLogAssociatedList]...';
GO
PRINT N'Creating [dbo].[netActivityLogAssociatedAnyList]...';
GO
PRINT N'Creating [dbo].[netActivityLogAssociatedAllList]...';
GO
PRINT N'Creating [dbo].[netNotificationMessageGet]...';
GO
PRINT N'Creating [dbo].[netNotificationMessagesTruncate]...';
GO
PRINT N'Creating [dbo].[netNotificationMessageGetForRecipients]...';
GO
PRINT N'Creating [dbo].[netNotificationMessageGetRecipients]...';
GO
PRINT N'Creating [dbo].[netNotificationMessagesRead]...';
GO
PRINT N'Creating [dbo].[netSynchedUserGetMetadata]...';
GO
PRINT N'Creating [dbo].[netNotificationMessagesDelete]...';
GO
PRINT N'Creating [dbo].[netNotificationMessagesSent]...';
GO
PRINT N'Creating [dbo].[netNotificationMessageInsert]...';
GO
PRINT N'Creating [dbo].[netNotificationMessageList]...';
GO
PRINT N'Creating [dbo].[netSynchedUserRoleUpdate]...';
GO
PRINT N'Creating [dbo].[netSynchedUserInsertOrUpdate]...';
GO
PRINT N'Creating [dbo].[netSiteDefinitionSave]...';
GO
PRINT N'Creating [dbo].[netSiteDefinitionDelete]...';
GO
PRINT N'Creating [dbo].[netSiteDefinitionList]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityDeleteItems]...';
GO
PRINT N'Creating [dbo].[netActivityLogCommentLoad]...';
GO
PRINT N'Creating [dbo].[netActivityLogAssociatedGetLowest]...';
GO
PRINT N'Creating [dbo].[netActivityLogGetAssociations]...';
GO
PRINT N'Creating [dbo].[netActivityLogAssociationDeleteRelated]...';
GO
PRINT N'Creating [dbo].[netActivityLogTruncate]...';
GO
PRINT N'Creating [dbo].[netActivityLogCommentList]...';
GO
PRINT N'Creating [dbo].[netActivityLogCommentSave]...';
GO
PRINT N'Creating [dbo].[netActivityLogCommentDelete]...';
GO
PRINT N'Creating [dbo].[netActivityLogAssociationDelete]...';
GO
PRINT N'Creating [dbo].[netActivityLogEntryDelete]...';
GO
PRINT N'Creating [dbo].[netActivityLogEntryLoad]...';
GO
PRINT N'Creating [dbo].[netActivityLogAssociationSave]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityMapContent]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityListProviders]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityDelete]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityGetByGuid]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityGetById]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityForProvider]...';
GO
PRINT N'Creating [dbo].[netMappedIdentityGetOrCreate]...';
GO
PRINT N'Creating [dbo].[netSynchedUserRolesListStatuses]...';
GO
PRINT N'Creating [dbo].[netSynchedUserRoleEnableDisable]...';
GO
PRINT N'Creating [dbo].[netProjectItemGetSingle]...';
GO
PRINT N'Creating [dbo].[netProjectItemGetByReferences]...';
GO
PRINT N'Creating [dbo].[netProjectItemGet]...';
GO
PRINT N'Creating [dbo].[netProjectItemDelete]...';
GO
PRINT N'Creating [dbo].[netProjectItemSave]...';
GO
PRINT N'Creating [dbo].[netProjectList]...';
GO
PRINT N'Creating [dbo].[netProjectDelete]...';
GO
PRINT N'Creating [dbo].[netProjectGet]...';
GO
PRINT N'Creating [dbo].[netProjectSave]...';
GO
PRINT N'Creating [dbo].[netContentListVersionsPaged]...';
GO
PRINT N'Creating [dbo].[editSetVersionStatus]...';
GO
PRINT N'Creating [dbo].[sp_FxDatabaseVersion]...';
GO
PRINT N'Creating [dbo].[EntityTypeGetNameByID]...';
GO
PRINT N'Creating [dbo].[EntityTypeGetIDByName]...';
GO
PRINT N'Creating [dbo].[EntitySetEntry]...';
GO
PRINT N'Creating [dbo].[EntityGetIdByGuidFromIdentity]...';
GO
PRINT N'Creating [dbo].[EntityGetIDByGuid]...';
GO
PRINT N'Creating [dbo].[EntityGetGuidByIdFromIdentity]...';
GO
PRINT N'Creating [dbo].[EntityGetGuidByID]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationSetInvalidWorker]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationSetInvalid]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationOpenConnection]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationEnqueueString]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationEnqueueInt]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationEnqueueGuid]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationCloseConnection]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationAccessConnectionWorker]...';
GO
PRINT N'Creating [dbo].[BigTableSaveReference]...';
GO
PRINT N'Creating [dbo].[BigTableDeleteItemInternal]...';
GO
PRINT N'Creating [dbo].[BigTableDeleteItem]...';
GO
PRINT N'Creating [dbo].[BigTableDeleteExcessReferences]...';
GO
PRINT N'Creating [dbo].[BigTableDeleteAll]...';
GO
PRINT N'Creating [dbo].[sp_DatabaseVersion]...';
GO
PRINT N'Creating [dbo].[netSynchedUserMatchRoleList]...';
GO
PRINT N'Creating [dbo].[netSynchedRolesList]...';
GO
PRINT N'Creating [dbo].[netSynchedRoleInsert]...';
GO
PRINT N'Creating [dbo].[netSynchedRoleDelete]...';
GO
PRINT N'Creating [dbo].[netSynchedUserList]...';
GO
PRINT N'Creating [dbo].[netSynchedUserRoleList]...';
GO
PRINT N'Creating [dbo].[netURLSegmentSet]...';
GO
PRINT N'Creating [dbo].[netURLSegmentListPages]...';
GO
PRINT N'Creating [dbo].[netUnmappedPropertyList]...';
GO
PRINT N'Creating [dbo].[netUniqueSequenceNext]...';
GO
PRINT N'Creating [dbo].[netTaskWorkflowList]...';
GO
PRINT N'Creating [dbo].[netTaskSaveActivity]...';
GO
PRINT N'Creating [dbo].[netTaskSave]...';
GO
PRINT N'Creating [dbo].[netTaskLoad]...';
GO
PRINT N'Creating [dbo].[netTaskList]...';
GO
PRINT N'Creating [dbo].[netTaskDelete]...';
GO
PRINT N'Creating [dbo].[netTabListDependencies]...';
GO
PRINT N'Creating [dbo].[netTabInfoUpdate]...';
GO
PRINT N'Creating [dbo].[netTabInfoList]...';
GO
PRINT N'Creating [dbo].[netTabInfoInsert]...';
GO
PRINT N'Creating [dbo].[netTabInfoDelete]...';
GO
PRINT N'Creating [dbo].[netSubscriptionListRoots]...';
GO
PRINT N'Creating [dbo].[netSoftLinksUpdateStatus]...';
GO
PRINT N'Creating [dbo].[netSoftLinksGetUnchecked]...';
GO
PRINT N'Creating [dbo].[netSoftLinksGetBrokenCount]...';
GO
PRINT N'Creating [dbo].[netSoftLinksGetBroken]...';
GO
PRINT N'Creating [dbo].[netSoftLinkByUrl]...';
GO
PRINT N'Creating [dbo].[netSoftLinkList]...';
GO
PRINT N'Creating [dbo].[netSoftLinkInsert]...';
GO
PRINT N'Creating [dbo].[netSoftLinkDelete]...';
GO
PRINT N'Creating [dbo].[netSoftLinkByPageLink]...';
GO
PRINT N'Creating [dbo].[netSoftLinkByExternalLink]...';
GO
PRINT N'Creating [dbo].[netSiteConfigSet]...';
GO
PRINT N'Creating [dbo].[netSiteConfigGet]...';
GO
PRINT N'Creating [dbo].[netSiteConfigDelete]...';
GO
PRINT N'Creating [dbo].[netSchedulerSetRunningState]...';
GO
PRINT N'Creating [dbo].[netSchedulerSetCurrentStatus]...';
GO
PRINT N'Creating [dbo].[netSchedulerSave]...';
GO
PRINT N'Creating [dbo].[netSchedulerReport]...';
GO
PRINT N'Creating [dbo].[netSchedulerRemove]...';
GO
PRINT N'Creating [dbo].[netSchedulerLoadJob]...';
GO
PRINT N'Creating [dbo].[netSchedulerListLog]...';
GO
PRINT N'Creating [dbo].[netSchedulerList]...';
GO
PRINT N'Creating [dbo].[netSchedulerGetNext]...';
GO
PRINT N'Creating [dbo].[netSchedulerExecute]...';
GO
PRINT N'Creating [dbo].[netSchedulerAdd]...';
GO
PRINT N'Creating [dbo].[netReportSimpleAddresses]...';
GO
PRINT N'Creating [dbo].[netReportReadyToPublish]...';
GO
PRINT N'Creating [dbo].[netReportPublishedPages]...';
GO
PRINT N'Creating [dbo].[netReportExpiredPages]...';
GO
PRINT N'Creating [dbo].[netReportChangedPages]...';
GO
PRINT N'Creating [dbo].[netRemoteSiteSave]...';
GO
PRINT N'Creating [dbo].[netRemoteSiteLoad]...';
GO
PRINT N'Creating [dbo].[netRemoteSiteList]...';
GO
PRINT N'Creating [dbo].[netRemoteSiteDelete]...';
GO
PRINT N'Creating [dbo].[netReadyToPublishList]...';
GO
PRINT N'Creating [dbo].[netQuickSearchByPath]...';
GO
PRINT N'Creating [dbo].[netQuickSearchByExternalUrl]...';
GO
PRINT N'Creating [dbo].[netPropertySearchNull]...';
GO
PRINT N'Creating [dbo].[netPropertySearchValueMeta]...';
GO
PRINT N'Creating [dbo].[netPropertySearchValue]...';
GO
PRINT N'Creating [dbo].[netPropertySearchStringMeta]...';
GO
PRINT N'Creating [dbo].[netPropertySearchString]...';
GO
PRINT N'Creating [dbo].[netPropertySearch]...';
GO
PRINT N'Creating [dbo].[netPropertySave]...';
GO
PRINT N'Creating [dbo].[netPropertyDefinitionTypeSave]...';
GO
PRINT N'Creating [dbo].[netPropertyDefinitionGetUsage]...';
GO
PRINT N'Creating [dbo].[netPropertyDefinitionDelete]...';
GO
PRINT N'Creating [dbo].[netPropertyDefinitionCheckUsage]...';
GO
PRINT N'Creating [dbo].[netPlugInSynchronize]...';
GO
PRINT N'Creating [dbo].[netPlugInSaveSettings]...';
GO
PRINT N'Creating [dbo].[netPlugInSave]...';
GO
PRINT N'Creating [dbo].[netPlugInLoad]...';
GO
PRINT N'Creating [dbo].[netPersonalRejectedList]...';
GO
PRINT N'Creating [dbo].[netPersonalNotReadyList]...';
GO
PRINT N'Creating [dbo].[netPersonalActivityList]...';
GO
PRINT N'Creating [dbo].[netPermissionSave]...';
GO
PRINT N'Creating [dbo].[netPermissionRoles]...';
GO
PRINT N'Creating [dbo].[netPermissionDeleteMembership]...';
GO
PRINT N'Creating [dbo].[netPageTypeGetUsage]...';
GO
PRINT N'Creating [dbo].[netPageTypeCheckUsage]...';
GO
PRINT N'Creating [dbo].[netPagesChangedAfter]...';
GO
PRINT N'Creating [dbo].[netPagePath]...';
GO
PRINT N'Creating [dbo].[netContentListPaged]...';
GO
PRINT N'Creating [dbo].[netPageListByLanguage]...';
GO
PRINT N'Creating [dbo].[netPageListAll]...';
GO
PRINT N'Creating [dbo].[netPageLanguageSettingUpdate]...';
GO
PRINT N'Creating [dbo].[netPageLanguageSettingListTree]...';
GO
PRINT N'Creating [dbo].[netPageLanguageSettingList]...';
GO
PRINT N'Creating [dbo].[netPageLanguageSettingDelete]...';
GO
PRINT N'Creating [dbo].[netPageDynamicBlockDelete]...';
GO
PRINT N'Creating [dbo].[netPageDynamicBlockList]...';
GO
PRINT N'Creating [dbo].[netPageDeleteLanguage]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionWithContentType]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionTypeList]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionTypeDelete]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionSave]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionList]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionGet]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionDynamicCheck]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionDefault]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionConvertSave]...';
GO
PRINT N'Creating [dbo].[netPageDefinitionConvertList]...';
GO
PRINT N'Creating [dbo].[netContentDataLoad]...';
GO
PRINT N'Creating [dbo].[netPageCountDescendants]...';
GO
PRINT N'Creating [dbo].[netPageChangeMasterLanguage]...';
GO
PRINT N'Creating [dbo].[netContentListBlobUri]...';
GO
PRINT N'Creating [dbo].[netLanguageBranchUpdate]...';
GO
PRINT N'Creating [dbo].[netLanguageBranchList]...';
GO
PRINT N'Creating [dbo].[netLanguageBranchInsert]...';
GO
PRINT N'Creating [dbo].[netLanguageBranchDelete]...';
GO
PRINT N'Creating [dbo].[netFrameUpdate]...';
GO
PRINT N'Creating [dbo].[netFrameList]...';
GO
PRINT N'Creating [dbo].[netFrameInsert]...';
GO
PRINT N'Creating [dbo].[netFrameDelete]...';
GO
PRINT N'Creating [dbo].[netFindContentCoreDataByID]...';
GO
PRINT N'Creating [dbo].[netFindContentCoreDataByContentGuid]...';
GO
PRINT N'Creating [dbo].[netDynamicPropertyLookup]...';
GO
PRINT N'Creating [dbo].[netDynamicPropertiesLoad]...';
GO
PRINT N'Creating [dbo].[netDelayPublishList]...';
GO
PRINT N'Creating [dbo].[netCreatePath]...';
GO
PRINT N'Creating [dbo].[netConvertPropertyForPageType]...';
GO
PRINT N'Creating [dbo].[netConvertPageType]...';
GO
PRINT N'Creating [dbo].[netContentTypeToContentTypeList]...';
GO
PRINT N'Creating [dbo].[netContentTypeSave]...';
GO
PRINT N'Creating [dbo].[netContentTypeList]...';
GO
PRINT N'Creating [dbo].[netContentTypeDeleteAvailable]...';
GO
PRINT N'Creating [dbo].[netContentTypeDelete]...';
GO
PRINT N'Creating [dbo].[netContentTypeAddAvailable]...';
GO
PRINT N'Creating [dbo].[netContentRootList]...';
GO
PRINT N'Creating [dbo].[netContentMove]...';
GO
PRINT N'Creating [dbo].[netContentMatchSegment]...';
GO
PRINT N'Creating [dbo].[netContentLoadLongString]...';
GO
PRINT N'Creating [dbo].[netContentListOwnedAssetFolders]...';
GO
PRINT N'Creating [dbo].[netContentCreateLanguage]...';
GO
PRINT N'Creating [dbo].[netContentCreate]...';
GO
PRINT N'Creating [dbo].[netContentChildrenReferences]...';
GO
PRINT N'Creating [dbo].[netContentAclSetInherited]...';
GO
PRINT N'Creating [dbo].[netContentAclList]...';
GO
PRINT N'Creating [dbo].[netContentAclDeleteEntity]...';
GO
PRINT N'Creating [dbo].[netContentAclDelete]...';
GO
PRINT N'Creating [dbo].[netContentAclChildDelete]...';
GO
PRINT N'Creating [dbo].[netContentAclChildAdd]...';
GO
PRINT N'Creating [dbo].[netContentAclAdd]...';
GO
PRINT N'Creating [dbo].[netChangeLogTruncBySeqNDate]...';
GO
PRINT N'Creating [dbo].[netChangeLogTruncByRowsNDate]...';
GO
PRINT N'Creating [dbo].[netActivityLogEntrySave]...';
GO
PRINT N'Creating [dbo].[netChangeLogGetRowsForwards]...';
GO
PRINT N'Creating [dbo].[netChangeLogGetRowsBackwards]...';
GO
PRINT N'Creating [dbo].[netChangeLogGetHighestSeqNum]...';
GO
PRINT N'Creating [dbo].[netChangeLogGetCountBackwards]...';
GO
PRINT N'Creating [dbo].[netChangeLogGetCount]...';
GO
PRINT N'Creating [dbo].[netCategoryStringToTable]...';
GO
PRINT N'Creating [dbo].[netCategorySave]...';
GO
PRINT N'Creating [dbo].[netCategoryListAll]...';
GO
PRINT N'Creating [dbo].[netCategoryDelete]...';
GO
PRINT N'Creating [dbo].[netCategoryContentLoad]...';
GO
PRINT N'Creating [dbo].[netBlockTypeGetUsage]...';
GO
PRINT N'Creating [dbo].[netBlockTypeCheckUsage]...';
GO
PRINT N'Creating [dbo].[editSetCommonDraftVersion]...';
GO
PRINT N'Creating [dbo].[editSavePropertyCategory]...';
GO
PRINT N'Creating [dbo].[editSaveContentVersionData]...';
GO
PRINT N'Creating [dbo].[editDeleteProperty]...';
GO
PRINT N'Creating [dbo].[editDeletePageCheck]...';
GO
PRINT N'Creating [dbo].[editDeletePage]...';
GO
PRINT N'Creating [dbo].[editDeleteChildsCheck]...';
GO
PRINT N'Creating [dbo].[editDeleteChilds]...';
GO
PRINT N'Creating [dbo].[editCreateContentVersion]...';
GO
PRINT N'Creating [dbo].[admDatabaseStatistics]...';
GO
PRINT N'Creating [dbo].[editDeletePageVersionInternal]...';
GO
PRINT N'Creating [dbo].[editDeletePageInternal]...';
GO
PRINT N'Creating [dbo].[editDeletePageCheckInternal]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_InitBlocks]...';
GO
PRINT N'Creating [dbo].[DateTimeConversion_InitFieldNames]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationTrySetValid]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationTrySetRecovering]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationHeartBeat]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationGetStatus]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationDequeueString]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationDequeueInt]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationDequeueGuid]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationCompleteBatchString]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationCompleteBatchInt]...';
GO
PRINT N'Creating [dbo].[ChangeNotificationCompleteBatchGuid]...';
GO
PRINT N'Creating [dbo].[netPropertySearchCategoryMeta]...';
GO
PRINT N'Creating [dbo].[netPropertySearchCategory]...';
GO
PRINT N'Creating [dbo].[netContentLoadVersion]...';
GO
PRINT N'Creating [dbo].[netContentEnsureVersions]...';
GO
PRINT N'Creating [dbo].[editContentVersionList]...';
GO
PRINT N'Creating [dbo].[editDeletePageVersion]...';
GO
PRINT N'Creating [dbo].[netContentTrimVersions]...';
GO
PRINT N'Creating [dbo].[editPublishContentVersion]...';
GO
PRINT N'Update complete.';
GO
SET IDENTITY_INSERT tblLanguageBranch ON
GO
INSERT INTO  tblLanguageBranch([pkID], [LanguageID], [Name], [SortIndex], [SystemIconPath], [URLSegment], [Enabled])
VALUES(1, 'en               ', NULL, 10, '~/app_themes/default/images/flags/en.gif', NULL, 1)
GO
VALUES(2, 'en-GB            ', NULL, 20, '~/app_themes/default/images/flags/en-gb.gif', NULL, 0)
GO
VALUES(3, 'en-NZ            ', NULL, 30, '~/app_themes/Default/Images/flags/en-NZ.gif', NULL, 0)
GO
VALUES(4, 'en-ZA            ', NULL, 40, '~/app_themes/default/images/flags/en-za.gif', NULL, 0)
GO
VALUES(5, 'de               ', NULL, 50, '~/app_themes/Default/Images/flags/de.gif', NULL, 0)
GO
VALUES(6, 'fr               ', NULL, 60, '~/app_themes/default/images/flags/fr.gif', NULL, 0)
GO
VALUES(7, 'es               ', NULL, 70, '~/app_themes/default/images/flags/es.gif', NULL, 0)
GO
VALUES(8, 'sv               ', NULL, 80, '~/app_themes/default/images/flags/sv.gif', NULL, 1)
GO
VALUES(9, 'no               ', NULL, 90, '~/app_themes/default/images/flags/no.gif', NULL, 0)
GO
VALUES(10, 'da               ', NULL, 100, '~/app_themes/default/images/flags/da.gif', NULL, 0)
GO
VALUES(11, 'fi               ', NULL, 110, '~/app_themes/default/images/flags/fi.gif', NULL, 0)
GO
VALUES(12, 'nl               ', NULL, 120, '~/app_themes/default/images/flags/nl.gif', NULL, 0)
GO
VALUES(13, 'nl-BE            ', NULL, 130, '~/app_themes/default/images/flags/nl-be.gif', NULL, 0)
GO
VALUES(14, 'pt-BR            ', NULL, 140, '~/app_themes/default/images/flags/pt-br.gif', NULL, 0)
GO
VALUES(15, '', NULL, 150, '', NULL, 0)
GO
SET IDENTITY_INSERT tblLanguageBranch OFF
GO
SET IDENTITY_INSERT tblCategory ON
GO
INSERT INTO tblCategory (pkID,fkParentID,CategoryGUID,SortOrder,Available,Selectable,SuperCategory,CategoryName,CategoryDescription) VALUES (
1,
NULL,
'{885BD5B6-9F33-4615-8E85-6390072E824C}',
1,
0,
0,
0,
'Root',
'Starting point')
GO
SET IDENTITY_INSERT tblCategory OFF
GO
SET IDENTITY_INSERT tblFrame ON
GO
INSERT INTO tblFrame (pkID,FrameName,FrameDescription,SystemFrame) VALUES (
1,
'target="_blank"',
'Open the link in a new window',
1)
GO
2,
'target="_top"',
'Open the link in the whole window',
1)
GO
SET IDENTITY_INSERT tblFrame OFF
GO
SET IDENTITY_INSERT tblPropertyDefinitionGroup ON
GO
INSERT INTO tblPropertyDefinitionGroup (pkID,SystemGroup,Access,GroupVisible,GroupOrder,Name) VALUES (
0,
1,
1,
1,
10,
'Information')
GO
1,
1,
4,
0,
30,
'Advanced')
GO
2,
1,
1,
0,
50,
'Categories')
GO
3,
1,
1,
0,
40,
'Shortcut')
GO
4,
1,
1,
0,
20,
'Scheduling')
GO
5,
1,
1,
0,
60,
'DynamicBlocks')
GO
SET IDENTITY_INSERT tblPropertyDefinitionGroup OFF
GO
INSERT INTO tblPropertyDefinitionType (pkID,Property,Name,TypeName,AssemblyName) VALUES (
0,
0,
'Boolean',
NULL,
NULL)
GO
1,
1,
'Number',
NULL,
NULL)
GO
2,
2,
'FloatNumber',
NULL,
NULL)
GO
3,
3,
'PageType',
NULL,
NULL)
GO
4,
4,
'PageReference',
NULL,
NULL)
GO
5,
5,
'Date',
NULL,
NULL)
GO
6,
6,
'String',
NULL,
NULL)
GO
7,
7,
'LongString',
NULL,
NULL)
GO
8,
8,
'Category',
NULL,
NULL)
GO
11,
11,
'ContentReference',
NULL,
NULL)
GO
SET IDENTITY_INSERT tblContentType ON
GO
INSERT INTO tblContentType (pkID,ContentTypeGUID,Created,Name,Description,IdString,Available,SortOrder,MetaDataInherit,MetaDataDefault,WorkflowEditFields) VALUES (
1,
'{3FA7D9E7-877B-11D3-827C-00A024CACFCB}',
'19990101 00:00',
'SysRoot',
'Used as root/welcome page',
'?id=',
0,
10000,
0,
0,
0)
GO
2,
'{4EEA90CD-4210-4115-A399-6D6915554E10}',
'19990101 00:00',
'SysRecycleBin',
'Used as recycle bin for the website',
'?id=',
0,
10010,
0,
0,
0)
GO
INSERT INTO tblContentType (pkID,ContentTypeGUID,Created,ModelType,Name,Description,IdString,Available,SortOrder,MetaDataInherit,MetaDataDefault,WorkflowEditFields,ContentType) VALUES (
3,
'{52F8D1E9-6D87-4DB6-A465-41890289FB78}',
'19990101 00:00',
'EPiServer.Core.ContentFolder,EPiServer',
'SysContentFolder',
'Used as content folder',
'?id=',
0,
10020,
0,
0,
0,
2)
GO
4,
'{E9AB78A3-1BBF-48ef-A8D4-1C1F98E80D91}',
'19990101 00:00',
'EPiServer.Core.ContentAssetFolder,EPiServer',
'SysContentAssetFolder',
'Used as a folder for content assets',
'?id=',
0,
10030,
0,
0,
0,
2)
GO
SET IDENTITY_INSERT tblContentType OFF
GO
Dependent data
SET IDENTITY_INSERT tblContent ON
GO
--SysRoot
INSERT INTO tblContent (pkID,fkContentTypeID,fkParentID,ArchiveContentGUID,CreatorName,ContentGUID,VisibleInMenu,Deleted,ChildOrderRule,PeerOrder, fkMasterLanguageBranchID,ContentPath, IsLeafNode) VALUES (
1,--pkID
1,--fkContentTypeID
NULL,--fkParentID
NULL,--ArchiveContentGUID
'',--CreatorName
'{43F936C9-9B23-4EA3-97B2-61C538AD07C9}',--ContentGUID
1,--VisibleInMenu
0,--Deleted
4,--ChildOrderRule
100,--PeerOrder
1,--fkMasterLanguageBranchID
'.',--ContentPath
0)--IsLeafNode
GO
--SysWastebasket
INSERT INTO tblContent (pkID,fkContentTypeID,fkParentID,ArchiveContentGUID,CreatorName,ContentGUID,VisibleInMenu,Deleted,ChildOrderRule,PeerOrder,fkMasterLanguageBranchID,ContentPath) VALUES (
2,--pkID
2,--fkContentTypeID
1,--fkParentID
'',--CreatorName
'{2F40BA47-F4FC-47AE-A244-0B909D4CF988}',--ContentGUID
1,--VisibleInMenu
0,--Deleted
1,--ChildOrderRule
10,--PeerOrder
'.1.')--ContentPath
GO
--SysGlobalAssets
INSERT INTO tblContent (pkID,fkContentTypeID,fkParentID,ArchiveContentGUID,CreatorName,ContentGUID,VisibleInMenu,Deleted,ChildOrderRule,PeerOrder,fkMasterLanguageBranchID,ContentPath,ContentType) VALUES (
3,--pkID
3,--fkContentTypeID
1,--fkParentID
'',--CreatorName
'{E56F85D0-E833-4E02-976A-2D11FE4D598C}',--ContentGUID
1,--VisibleInMenu
0,--Deleted
3,--ChildOrderRule
100,--PeerOrder
15,--fkMasterLanguageBranchID
'.1.',--ContentPath
2)--ContentType
GO
--SysContentAssets
4,--pkID
3,--fkContentTypeID
1,--fkParentID
'',--CreatorName
'{99D57529-61F2-47C0-80C0-F91ECA6AF1AC}',--ContentGUID
1,--VisibleInMenu
0,--Deleted
3,--ChildOrderRule
100,--PeerOrder
'.1.',--ContentPath
2)--ContentType
GO
SET IDENTITY_INSERT tblContent OFF
GO
INSERT INTO tblUserPermission (Name, IsRole, GroupName, Permission) VALUES ('Administrators',1,'EPiServerCMS', 'DetailedErrorMessage')    /* DetailedErrorMessage */
GO
INSERT INTO tblContentAccess (fkContentID,Name,IsRole,AccessMask) VALUES (1,'Everyone',1,1)
GO
INSERT INTO tblContentAccess (fkContentID,Name,IsRole,AccessMask) VALUES (2,'Everyone',1,1)
GO
INSERT INTO tblContentAccess (fkContentID,Name,IsRole,AccessMask) VALUES (1,'Administrators',1,63)
GO
INSERT INTO tblContentAccess (fkContentID,Name,IsRole,AccessMask) VALUES (2,'Administrators',1,63)
GO
INSERT INTO tblTree (fkParentID,fkChildID,NestingLevel) VALUES (1,2,1)
GO
INSERT INTO tblTree (fkParentID,fkChildID,NestingLevel) VALUES (1,3,1)
GO
INSERT INTO tblTree (fkParentID,fkChildID,NestingLevel) VALUES (1,4,1)
GO
--Root
DECLARE @fkPageId1 INT
INSERT INTO tblWorkContent (fkContentID ,fkMasterVersionID, ContentLinkGUID, fkFrameID, ArchiveContentGUID, ChangedByName, NewStatusByName, Name, URLSegment,LinkURL ,ExternalURL ,VisibleInMenu ,LinkType ,Created ,Saved ,StartPublish ,StopPublish ,ChildOrderRule ,PeerOrder ,ChangedOnPublish ,RejectComment ,fkLanguageBranchID, Status) VALUES (
1, --fkContentID
null, --,fkMasterVersionID
null, --,ContentLinkGUID
null,--,fkFrameID
null,--,ArchiveContentGUID
'', --,ChangedByName
null, --,NewStatusByName
'Root',--Name
null, --,URLSegment
'~/link/43F936C99B234EA397B261C538AD07C9.aspx',--LinkURL
null, --,ExternalURL
1, --,VisibleInMenu
0, --,LinkType
'19990101 00:00', --,Created
'19990101 00:00', --,Saved
'19990101 00:00', --,StartPublish
null, --,StopPublish
4, --,ChildOrderRule
100, --,PeerOrder
0, --,ChangedOnPublish
null,--,RejectComment
1,--,fkLanguageBranchID
4 --status
SET @fkPageId1=@@IDENTITY
--RecycleBin
DECLARE @fkPageId2 INT
2, --fkContentID
null,--,fkFrameID
'Recycle Bin',--Name
null, --,URLSegment
'~/link/2F40BA47F4FC47AEA2440B909D4CF988.aspx',--LinkURL
1, --,VisibleInMenu
0, --,LinkType
1, --,ChildOrderRule
10, --,PeerOrder
4 --Status
SET @fkPageId2=@@IDENTITY
DECLARE @fkPageId3 INT
3, --fkContentID
null,--,fkFrameID
'SysGlobalAssets',--Name
'SysGlobalAssets', --,URLSegment
null,--LinkURL
1, --,VisibleInMenu
0, --,LinkType
3, --,ChildOrderRule
100, --,PeerOrder
15,--,fkLanguageBranchID
4 -- Status
SET @fkPageId3=@@IDENTITY
DECLARE @fkPageId4 INT
4, --fkContentID
null,--,fkFrameID
'SysContentAssets',--Name
'SysContentAssets', --,URLSegment
null,--LinkURL
1, --,VisibleInMenu
0, --,LinkType
100, --,PeerOrder
4 --Status
SET @fkPageId4=@@IDENTITY
INSERT INTO tblContentLanguage (fkContentID,fkLanguageBranchID,ContentLinkGUID,fkFrameID,CreatorName,ChangedByName,ContentGUID,Name,LinkURL,ExternalURL,AutomaticLink,FetchData,Created,Changed,Saved,StartPublish,StopPublish,[Version], Status) VALUES (
1,--fkContentID
1,--fkLanguageBranchID
NULL,--ContentLinkGUID
NULL,--fkFrameID
'',--CreatorName
'',--ChangedByName
'Root',--Name
NULL,--ExternalURL
1,--AutomaticLink
0,--FetchData
'19990101 00:00',--Created
'19990101 00:00',--Changed
'19990101 00:00',--Saved
'19990101 00:00',--StartPublish
NULL,--StopPublish
@fkPageId1,--Version
4 --Status
INSERT INTO tblContentLanguage (fkContentID,fkLanguageBranchID,ContentLinkGUID,fkFrameID,CreatorName,ChangedByName,ContentGUID,Name,URLSegment,LinkURL,ExternalURL,AutomaticLink,FetchData,Created,Changed,Saved,StartPublish,StopPublish,[Version], Status) VALUES (
2,--fkContentID
NULL,--fkFrameID
'',--CreatorName
'',--ChangedByName
'Recycle-Bin',--URLSegment
NULL,--ExternalURL
1,--AutomaticLink
0,--FetchData
NULL,--StopPublish
@fkPageId2,--Version
4 --Status
3,--fkContentID
15,--fkLanguageBranchID
NULL,--fkFrameID
'',--CreatorName
'',--ChangedByName
'SysGlobalAssets',--URLSegment
null,--LinkURL
NULL,--ExternalURL
1,--AutomaticLink
0,--FetchData
NULL,--StopPublish
@fkPageId3,--Version
4 --Status
4,--fkContentID
NULL,--fkFrameID
'',--CreatorName
'',--ChangedByName
'SysContentAssets',--URLSegment
null,--LinkURL
NULL,--ExternalURL
1,--AutomaticLink
0,--FetchData
NULL,--StopPublish
@fkPageId4,--Version
4 --Status
GO
#157857
Sep 23, 2016 10:33
