For cheap solution, use image resizer.NET component. This has support for everything you ever want to do with an image and more. There are nuget package for both the component and the small fixes you need to do to enable episerver to use it. Works great :)
Hi guys i've implementet image cropping as per:
http://world.episerver.com/blogs/Mark-van-Dijk/Dates/2014/11/extending-the-imagedescriptor-attribute/
But clients are saying that images are loosing quality after resize and crop. I found that this part of the code is doing croping
and i tried changing 50 to 100 (parameter that controls image quality) but no luck.
Also when client is croping images in image editor trough edit window they say quality is ok but they whant that proces to be automatic.
Any ideas how to fix this ?
