EPiServer CMS UI AspNetIdentity OWIN authentication
Trying to setup a blank EPiServer site with the AspNetIdentity authentication system. Following the instructions here: http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/9/Security/episerver-aspnetidentity/, here http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/9/Security/aspnet-identity-owin-authentication/ and also looking in the QuickSilbver template site it feels I have setup everything needed to run it.
I have installed the nuget package EPiServer.CMS.UI.AspNetIdentity, setup a SiteUser inheriting from IdentityUser and IUIUser, and created the Startup class.
I have also used the aspnet_identity.sql file from the QuickSilver solution to fill the database with some base users.
When accessing the /episerver url I am redirected to the /Util/Login.aspx as usual but when after logging in with a user I get the following error message not giving to much information:
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
   EPiServer.UI.WebControls.Login.OnAuthenticate(AuthenticateEventArgs e) +100
   System.Web.UI.WebControls.Login.AttemptLogin() +145
   System.Web.UI.WebControls.Login.OnBubbleEvent(Object source, EventArgs e) +114
   System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +49
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +6015
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.1069.1
Update:
Setting the app.AddCmsAspNetIdentity(new ApplicationOptions() { ConnectionStringName = "EPiServerDB" }); I get another error message
Invalid column name 'IsApproved'.
Invalid column name 'IsLockedOut'.
Invalid column name 'Comment'.
Invalid column name 'CreationDate'.
Invalid column name 'LastLoginDate'.
Invalid column name 'LastLockoutDate'.
Exception Details: System.Data.SqlClient.SqlException: Invalid column name 'IsApproved'.
Source Error:
Stack Trace:
[SqlException (0x80131904): Invalid column name 'IsApproved'.
Invalid column name 'LastLockoutDate'.]
   System.Data.SqlClient.<>c.b__167_0(Task`1 result) +1166158
   System.Threading.Tasks.ContinuationResultTaskFromResultTask`2.InnerInvoke() +108
   System.Threading.Tasks.Task.Execute() +71
   System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) +13847892
   System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) +61
   System.Data.Entity.Core.EntityClient.Internal.d__c.MoveNext() +419
This is because the database is not updated with the properties from the EPiServer ApplicationUser. But to fix this I think I need to run migrations but trying the enable-migrations on the project from the Package Manager console only gives me the error message No context type was found in the assembly .
How do I properly initialie the database to be used with EPiServers AspNetIdentity?
#151628
Edited, Aug 01, 2016 14:36
After some more trying I have got it working
I had to create a EPiServerDbContext inheriting from IdentityDbContext like this
public class EPiServerDbContext : IdentityDbContext<ApplicationUser>
        public EPiServerDbContext() : base("EPiServerDB", throwIfV1Schema: false)
        public static EPiServerDbContext Create()
            return new EPiServerDbContext();
After this I was able to do enable-migrations in the Package Manager Console.
Trying to do update-database told me about some pending changes so i ran Add-Migration UserUpdate and got a DBMigration which would create the tables needed for the User management.
After this I could run update-database and it created the tables.
To add a user I then added the following to the Seed method in the Configuration class created by the enable-migrations command
context.Users.AddOrUpdate(u => u.Id,
                new EPiServer.Cms.UI.AspNetIdentity.ApplicationUser
                    Id = "6008ecc6-a5a8-49dc-a47c-c1db614df77c",
                    CreationDate = DateTime.Now,
                    Email = "admin@site.se",
                    EmailConfirmed = true,
                    IsApproved = true,
                    IsLockedOut = false,
                    Username = "admin",
                    PasswordHash = "AAwsxpbbay95Ig5UUtJfqrz5QQZDWbbJShgza2BVP9sZAEaDvoC+UZ6HP1ER3b94FQ==",
                    SecurityStamp = "989acc4f-30bd-425d-9b20-7c7f85bee15b",
                    UserName = "admin",
                    TwoFactorEnabled = false,
                    LockoutEnabled = false,
                    AccessFailedCount = 0
            context.Roles.AddOrUpdate(r => r.Name,
                new IdentityRole
                    Name = "Administrators"
                new IdentityRole
                    Name = "WebAdmins"
                new IdentityRole
                    Name = "WebEditors"
            context.SaveChanges();
            var userManager = new UserManager<ApplicationUser>(new UserStore<ApplicationUser>(context));
            userManager.AddToRole("6008ecc6-a5a8-49dc-a47c-c1db614df77c", "Administrators");
That will create an admin user with the password store, connected to the Administrators role, that can be used to log in to the site with. Just run update-database after you have saved and built the project to create the user.
It feels like EPiServer needs to update their article describing this a bit...
#151636
Edited, Aug 01, 2016 17:03
Thanks, this was helpful. It's a little crazy that you can specify a custom identity model in the startup with custom properties, but you need to create your own duplicated context to get migrations to be applied.
app.AddCmsAspNetIdentity<CustomUser>();
If anyone is interested in code-based migrations, you can specify a use Tobias' post above to make your own custom DB Context
public class EPiServerDbContext : IdentityDbContext<CustomUser>
After, you can use Nuget console to run
Enable-Migrations
Which will generate the following:
internal sealed class Configuration : DbMigrationsConfiguration<YourNamespace.EPiServerDbContext>
        public Configuration()
            AutomaticMigrationsEnabled = false;
        protected override void Seed(YourNamespace.EPiServerDbContext context)
All you need to do then is add a ContextKey matching what the site specifies in the _MigrationHistory SQL table. For the Social Alloy site, that's:
            ContextKey = "EPiServer.Cms.UI.AspNetIdentity.ApplicationDbContext`1[EPiServer.Cms.UI.AspNetIdentity.ApplicationUser]";
From there, you can add properties to your custom IdentityUser (mine is CustomUser) and run
Add-Migration "<MigrationName>"
Update-Database
Enjoy.
#177894
Edited, Apr 23, 2017 6:02
