Episerver 9 - creating users in Azure AD B2C
Has anyone connected to an Azure B2C Active Directory and has created a way to dynamically create Users into the Directory without using the Default Microsoft Pop up (using Azure B2C Graph)?
Also, what is really important we need to create the Username as the user's email address for example: test@mysite.com and NOTtest@TFS.onmicrosoft.com.
Jon
#152653
Aug 26, 2016 18:03
Have you found and checked this project? https://github.com/Azure-Samples/active-directory-dotnet-graphapi-console
It's as you can see fairly easy to write and update stuff. I don't know about the username setting but should be easy to test.
#155215
Sep 12, 2016 15:26
