Although it's for EPiServer 7 this guide http://www.david-tec.com/2012/06/Comparing-PageTypeBuilder-and-EPiServer-7-Preview-typed-pages-part-3-of-3/ has the following.
Set on the pages/blocks overriden SetDefaultValues
this.Properties["PageChildOrderRule"].Value = EPiServer.Filters.FilterSortOrder.CreatedDescending;
I've not tried it however but the FilterSortOrder enum is still there in EPiServer 9
I can confirm that this works, we use it in projects:
this[MetaDataProperties.PageChildOrderRule] = FilterSortOrder.PublishedDescending;
BR,
Marija
Thanks, this does the trick. I was hoping there is an attribute which I can use to decorate my classes.
In EPiServer 6 we could change a default order sort order of child pages using PageTypeBuilder.
Is there something similar in EPiServer 8?
