enum to render display names in cms editor
I have an enum property in the block model.
public enum TextFieldSize { Small, Standard, Large }
[BackingType(typeof(PropertyNumber))]
[EditorDescriptor(EditorDescriptorType = typeof(EnumSelector))]
[Display(
Name = "Field size",
Description = "Determines width of field displayed",
Order = 50)]
public virtual TextFieldSize FieldSize { get; set; }
FieldSize = TextFieldSize.Standard;
In the CMS editor, it displays the dropdown with the list of enums (Small, Standard, Large).
But I want to have display name for each. That is, instead of 'Small' I want to display as 'Small - Single Line'.
Small - Small - Single Line
Standard - Standard - Single Line
Large - Large - Multi line
I have change the enum property to
public enum TextFieldSize { [Display(Name = "Small - Single line")]Small, [Display(Name = "Standard - Single line")]Standard, [Display(Name = "Large - Multi line")]Large }
but it's does show any display names.
#152255
Aug 22, 2016 18:19
[EditorDescriptor(EditorDescriptorType = typeof(EnumEditorDescriptor<SomeEnum>))]
then
public class EnumEditorDescriptor<TEnum> : EditorDescriptor where TEnum : struct, IComparable, IConvertible, IFormattable
        SelectionFactoryType = typeof(EnumSelectionFactory<TEnum>);
        ClientEditingClass = "epi-cms/contentediting/editors/SelectionEditor";
public class EnumSelectionFactory<TEnum> : ISelectionFactory
    public IEnumerable<ISelectItem> GetSelections(ExtendedMetadata metadata)
        var values = Enum.GetValues(typeof(TEnum))
                .OfType<object>()
                .Select(x=> new SelectItem { Text = "HERE-EXTRACT-TEXT-FROM-LOCALIZATION-SERVICE", Value = x});
        return values;
#155046
Sep 08, 2016 11:05
Maybe I'm misunderstanding this but shouldn't it be possible to put this in a language XML resource file in //languages/language node:
<property>
    <enum>
        <textfieldsize>
            <small>Small - Single line</small>
            <standard>Standard - Single line</standard>
            <large>Large - Single line</large>
        </textfieldsize>
    </enum>
</property>
#155052
Sep 08, 2016 12:26
Yes, that should also work. We were just using localization service n ot based on Xml language files.. therefore needed programmatic access
#155056
Sep 08, 2016 12:49
