Weird IContentLoader error
I have weird IContentLoader error and wondered if anyone can shed any light on what's causing it.
I have the code:
            var loader = ServiceLocator.Current.GetInstance();
            var contentBlock = loader.Get(Guid);
            if (contentBlock != null)
                var test = contentBlock.SomeProperty;
And the contentBlock is not null but when trying to access the property it throws a massive error.
When I check contentBlock in the immediate window I get the message "Cannot obtain value of local or argument 'contentBlock' as it is not available at this instruction pointer, possibly because it has been optimized away."
But if I do something like var contentBlock1 = loader.Get(Guid); in the immediate window then I get the block returned as expected.
Any thoughts on what's happening here?
Mark
#151149
Jul 12, 2016 13:45
Shared or local block on a page type?
#151150
Jul 12, 2016 14:59
At the moment it's happening when a shared block, I've not tested with a local block. The block in question is actually a FormContainerBlock inherited from the EPiServer so that I can add additional properties to the Form.
#151151
Jul 12, 2016 15:07
Isn't this a standard .NET message that can happen when you debug release built assemblies? Like mentioned here: http://stackoverflow.com/questions/8311303/cannot-obtain-value-of-local-or-argument-as-it-is-not-available-at-this-instruct
Regards
Per Gunsarfs
#151155
Jul 12, 2016 16:05
Hi Per,
I had seen that article and tried all the suggestions it contained and all my VS settings were and are as recommended. The issue is happening in a Bll component project so the code optimization scenario seems a valid cause. It was actually working yesterday and I thought it was caused by the naming of the variable but then it stopped working again today. Frustrating...
Mark
#151156
Jul 12, 2016 16:33
Clear temporary files and rebuild?
#151158
Jul 12, 2016 17:15
I've already tried that and it made no difference. It must be a VS debug issue, if I run the code without debugging it does not error. Makes it difficult if I need to debug though...
#151159
Jul 12, 2016 17:20
Yup. Add some logging with log4net if you need I guess :)
Sounds like you are running in release mode from the error...
#151161
Edited, Jul 12, 2016 17:53
