Hi Patrik,
Do you have @Html.RequiredClientResources("Footer") in your Layout page?
I tested forms 3.0.0 with Alloy. I tried to disable ClientValidationEnabled and UnobtrusiveJavaScriptEnabled in the web.config, set Html.EnableClientValidation(false); and Html.EnableUnobtrusiveJavaScript(false); int the razor view, etc. Client-side validation is always triggered.
The only time when the postback was triggered (which showed server-side error messages and cleared the form fields) was when I removed @Html.RequiredClientResources("Footer") from the Layout page.
Hi guys,
I'm trying out EPiServer Forms 3.0.0. Some of my test form's fields has the Required validator checked, and when I try to submit a form which gives errors (for instance "Validation failed on 'Name' field"), all the other fields are cleared. I have to re-enter data again. Anyone seen this before?
BR
Patrik
