Episerver forms - Overwriting submission data
Hello, Iam trying to overwrite input values on a submission on the formssubmitting event. This is my code:
    [InitializableModule]
    public class EpiserverFormsInitializationModule : IConfigurableModule
        private Injected _formRepository;
        private Injected _contentLoader;
            context.Container.Configure(ConfigureContainer);
        private static void ConfigureContainer(ConfigurationExpression container)
            container.For().Use();
            FormsEvents.Instance.FormsSubmitting += Instance_FormsSubmitting;
        private void Instance_FormsSubmitting(object sender, FormsEventArgs e)
            var request = HttpContext.Current.Request;
            var pageReference = UrlResolver.Current.Route(new UrlBuilder(request.UrlReferrer)).ContentLink;
            var submission = e as FormsSubmittingEventArgs;
            IContent content = _contentLoader.Service.Get(e.FormsContent.ContentLink);
            ILocalizable localizable = content as ILocalizable;
            if (content == null || localizable == null || submission == null)
                return;
            FormIdentity formsId = new FormIdentity(e.FormsContent.ContentGuid, localizable.Language.Name);
            var friendlyNameInfos = _formRepository.Service.GetDataFriendlyNameInfos(formsId);
            var friendlyPageId = friendlyNameInfos.FirstOrDefault(x => x.FriendlyName == "PageID");
            if (friendlyPageId != null && !friendlyPageId.FriendlyName.IsNullOrWhiteSpace())
                var pageId = submission.SubmissionData.Data.FirstOrDefault(x => x.Key == friendlyPageId.ElementId);
                submission.SubmissionData.Data.Remove(pageId);
                pageId = new KeyValuePair(pageId.Key, pageReference.ID);
                submission.SubmissionData.Data.Add(pageId);
This code works and replaces the value of the in this case "pageID" input field that i have in my form. When i export the submission forms from episerver edit i get a list that represents the new value correctly. But in the "Forms submissions" tab in episerver edit in a form the view is empty.
If i remove the code that adds a new keypair value and post my form again the view is full again and the forms where i changed the "pageID" are also there with the new value.
I need a better way to go about this because i think iam missing something, thanks!
#150936
Jul 04, 2016 11:10
Found the problem :)
pageId = new KeyValuePair<string, object>(pageId.Key, pageReference.ID);
should have been
pageId = new KeyValuePair<string, object>(pageId.Key, pageReference.ID.ToString());
Database was not expecting an int, its always the little things that get you..
#150951
Edited, Jul 05, 2016 10:41
