1. Use tinymce editor and use that.
2. Use the example string list property in alloy and render that as a bullet list.
3. Use a Linkitemcollection and point to target pages that contain each string. If you have pretty fixed strings this is a decent solution that is also possible to extend.
We used to be able to use TinyMCE to create bullet lists, add HTML, but that has apparently stopped working at some point. We have existing blocks of content in production, but now when we try to edit those with TinyMCE, the HTML is stripped out. In additon, when I try and add HTML it gets stripped out on Publish.
It is possible to allow the editor to create a bullet point lists? I had search this, but I don't find the component that allow me to do this. The only way that I think sould work is using the wysiwyg component.
