Problem to Host in IIS
Hi ,
After hosting my EPi site in IIS , while browsing the same , I am getting the following error after login(using windows authentication)
Content with id '183' is of type 'Castle.Proxies.ArticlePageProxy' which does not inherit required type 'EPIServerExtranet.Models.Pages.StartPage'
Exception Details: EPiServer.Core.TypeMismatchException: Content with id '183' is of type 'Castle.Proxies.ArticlePageProxy' which does not inherit required type 'EPIServerExtranet.Models.Pages.StartPage'
Source Error:
Stack Trace:
[TypeMismatchException: Content with id '183' is of type 'Castle.Proxies.ArticlePageProxy' which does not inherit required type 'EPIServerExtranet.Models.Pages.StartPage']
   EPiServer.Core.DefaultContentLoader.ThrowTypeMismatchException(ContentReference link, Type actual, Type required) +171
   EPiServer.Core.DefaultContentLoader.Get(ContentReference contentLink, LoaderOptions loaderOptions) +373
   EPIServerExtranet.Business.PageViewContextFactory.CreateLayoutModel(ContentReference currentContentLink, RequestContext requestContext) +107
   EPIServerExtranet.Business.PageContextActionFilter.OnResultExecuting(ResultExecutingContext filterContext) +210
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +236
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +833
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +81
Please let me know what I need to do here.
Thanks in advance.
#150177
Jun 13, 2016 12:30
Sounds like you have a bad casting to StartPage somewhere in the
So check that method and see if it tries to cast the current page to a startpage. Looks like you have a call like
contentRepository.Get<StartPage>(currentContentLink)
or similar which will crash and burn because currentContentLink points to an article page.
Instead do something like:
var currentPage = contentRepository.Get<IContent>(currentContentLink);
var startPage = currentPage as StartPage;
if(startPage!=null)
//Create layout if you are on start page....
#150188
Jun 13, 2016 15:46
