No user with username IIS APPPOOL\MyWebsite was found Cannot insert the value NULL into column 'fkSynchedUser', table 'NewJabil.dbo.tblSynchedUserRelations'; column does not allow nulls. INSERT fails.
Hi All,
Whenevr I am trying to access any page in view mode I am getting following error,But i am able to view the page in edit mode,
MyWebsite is the name of App Pool which is being used by application
Exception Details: System.Data.SqlClient.SqlException: No user with username IIS APPPOOL\MyWebsite was found
Source Error:
Stack Trace:
[SqlException (0x80131904): No user with username IIS APPPOOL\MyWebsite was found
Cannot insert the value NULL into column 'fkSynchedUser', table 'NewJabil.dbo.tblSynchedUserRelations'; column does not allow nulls. INSERT fails.]
   System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +3279580
   System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +791
   System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4927
   System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +442
   System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds, Boolean describeParameterEncryptionRequest) +3114
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite) +554
   System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean asyncWrite) +475
   System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +386
   EPiServer.Data.Providers.<>c__DisplayClass32.b__31() +15
   EPiServer.Data.Providers.<>c__DisplayClass35`1.b__34() +192
   EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +967
   EPiServer.Security.SynchronizingUserService.SynchronizeUserAndClaims(String userName, IEnumerable`1 claims) +337
   EPiServer.Security.WindowsRoleProvider.GetRolesForUser(String username) +647
   System.Web.Security.RolePrincipal.GetRoles() +272
   System.Web.Security.d__4.MoveNext() +72
   System.Security.Claims.d__51.MoveNext() +411
   System.Security.Principal.d__95.MoveNext() +230
   System.Linq.WhereSelectEnumerableIterator`2.MoveNext() +118
   System.Linq.d__63`1.MoveNext() +333
   System.Collections.Generic.HashSet`1.UnionWith(IEnumerable`1 other) +107
   System.Collections.Generic.HashSet`1..ctor(IEnumerable`1 collection, IEqualityComparer`1 comparer) +156
   EPiServer.Security.VirtualRoleToClaimConverter.AddClaims(IPrincipal principal) +873
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +142
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +92
#150455
Jun 18, 2016 23:33
