@Html.PropertyFor unable to refer
I am unable to refer
@Html.PropertyFor in my cshtml file. I added all the necessary dlls but cshtml is not recognizing the syntax.  Is there anything else I can verify?
Anyone else faced the issue? I am using EPI 7.11 version.
This is the error I am getting
CS1061'HtmlHelper' does not contain a definition for 'PropertyFor' and no extension method 'PropertyFor' accepting a first argument of type 'HtmlHelper'
could be found (are you missing a using directive or an assembly reference?)StartPage\Index.cshtml
I have the below package added to the project.
#149589
Jun 04, 2016 4:25
Check that you have added the namespace in /views/web.config (or have a @using statement in your .cshtml)
  <system.web.webPages.razor>
    <host factoryType="System.Web.Mvc.MvcWebRazorHostFactory, System.Web.Mvc, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" />
    <pages pageBaseType="System.Web.Mvc.WebViewPage">
      <namespaces>
        <add namespace="System.Web.Mvc" />
        <add namespace="System.Web.Mvc.Ajax" />
        <add namespace="System.Web.Mvc.Html" />
        <add namespace="System.Web.Routing" />
        <add namespace="EPiServer.Web.Mvc.Html" />
        <add namespace="EPiServer.Shell.Web.Mvc.Html" />
      </namespaces>
    </pages>
  </system.web.webPages.razor>
The PropertyFor extension method in in EPiServer.Web.Mvc.Html
#149590
Jun 04, 2016 10:09
yes. When I added the reference inside View->Web.config it worked. Thank you
#149600
Jun 05, 2016 5:47
