How to design View Models with EPI
I am developing a commernce site and need to deal with a lot of data. What's the best way to design the View Models and the Page types and block types?
Curently, I am referring the Page Type inside the View Model and passing the model to the view. This is working fine. But when I need to use Blocks, this is not working. BlocksData is referred by the MainContentArea using @Html.PropertyFor and I am not finding any way to pass the data or view model to the Block template. I tried many options to pass the data and but nothing seems to work.
Am I doing correct by referring the page type inside a View Model? A sample view model and controller is below.
public class DeliveryViewModel : BaseViewModel
/// Gets or sets the current page.
/// The current page.
public DeliveryPage CurrentPage { get; set; }
/// Gets or sets the Transaction data.
/// The conversion data.
public List TransactionData { get; set; }
/// Gets or sets the promotion code.
/// The promotion code.
public string PromotionCode { get; set; }
public class DeliveryPage : CommonOrderDetails
public virtual ContentArea MainContentArea { get; set; }
public class TransactionBlock : BlockData
[Display(
Name = "Header",
Description = "Enter a header for the block",
Order = 1)]
[Required]
public virtual string Header { get; set; }
[Display(
Name = "Description",
Description = "Enter a Description for the block",
Order = 2)]
[Required]
public virtual XhtmlString Description { get; set; }
public ActionResult Index(DeliveryPage currentPage)
var model = new DeliveryViewModel();
model.CurrentPage = currentPage;
return this.View(model);
public class TransactionBlockController : BlockController
public override ActionResult Index(TransactionBlock currentblock)
return PartialView(currentblock);
And Inside the Delivery-> Index.cshtml I am calling the MainContentArea like below
@foreach (var model in Model.TransactionData)
{@Html.PropertyFor(x => x.CurrentPage.MainContentArea)
Is this correct? Is there any better way?
#149804
Jun 08, 2016 5:19
Checkout the Alloy demo project way of handling viewmodel. I like that way.
Normally you just call Html.PropertyFor() to render the content area including any blocks within it. So that foreach loop looks wrong...
#150578
Jun 22, 2016 19:30
