Forms : multiple dropdowns in one control
I want to have multiple dropdowns within a form custom control.
The following will render one dropdownlist. But I want to add another 4 dropdowns in addition to the one below.
The property name 'Items' is obtained from SelectionElementBlockBase and can only be used once to render one dropdown.
How can I create another dropdown using the approach below. SelectionElementBlockBase seems to allow one dropdown only
Public class selectlistsblock : SelectionElementBlockBase
[Ignore]
public override IEnumerable Items
get
var lst = new List();
var cats = GetCategories("department");
foreach (var cat in cats)
yield return new OptionItem { Caption = cat.LocalizedDescription, Value = cat.LocalizedDescription, Checked = false };
#150558
Jun 22, 2016 14:04
Why not add 4 elements for dropdowns into the same Form Container Block?
Could you otherwise give an example on your case what should have 4 dropdowns and why they need to be in one control?
#150581
Jun 22, 2016 21:25
