Try to configure <episerver.dataStore> element (NB! changes here are affecting whole site) and set <dataSettings @databaseQueryTimeout>.
It however wasn't affecting necessary SqlCommand settings in this case, maybe that might help in your situation. Just curious..
Had some issues with this too. Our workaround was to use the schedule job (Automatic Emptying of Trash) and run it manually a couple of times and then delete the rest by clicking the "Empty Trash"-button.
Its a product feature, that should work with large scale websites also without any developers involvement.
Regards
/K
If you still have the database with the trash intact please open a support so we can get access to it.
Hi Per,
Thanks for the response, I will try to arrange that.
Regards
/K
Our Production website is fairly large website. Where Empty Trash functionality Never work, (Automatic Emptying of Trash Job sometime will delete 2/3 entries.)
The Exception we get on clicking Empty Trash is following
[SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.]
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean asyncWrite)
at EPiServer.DataAccess.ContentSaveDB.<>c__DisplayClass17_0.b__0()>
at EPiServer.Data.Providers.SqlDatabaseHandler.<>c__DisplayClass29_0.b__0()>
at EPiServer.Data.Providers.SqlDatabaseHandler.<>c__DisplayClass30_0`1.b__0()>
at EPiServer.Core.DefaultContentRepository.DeleteChildren(ContentReference contentLink, Boolean forceDelete, AccessLevel access)
at EPiServer.Cms.Shell.UI.Rest.WasteBasketStore.Empty(ContentReference id)
at lambda_method(Closure , ControllerBase , Object[] )
The work arround is
run this SP in Sql server explorer. (It takes hours in our case)
EXEC @return_value = [dbo].[editDeleteChilds]
@PageID = 2,
@ForceDelete = 1
I am wondering Can this bug be prioritized and fixed. I can see this bug have a long history.
Regards
Khurram
