After hosting the application Media file is not loading
After hosting the application media block images and video files are not loading. It shows 404 Not Found
#150231
Jun 14, 2016 13:17
Check that you have also copied the appData folder where the images are stored and not just the database. Check that access rights for IUSR are set to read at least...
Also check that the setting in EpiserverFramework.config is correct for appData folder
<episerver.framework updateDatabaseSchema="true">
<appData basePath="..\..\appdata" />
Happy coding!
#150233
Edited, Jun 14, 2016 13:56
