Adding a shortcut pane in assets widget
I'm working on a project that has a lot of content folders in a hierarchy that makes it a bit diffucult to navigate. My idea is to add a new navigation pane, as Episerver.Forms does, to the asset widget. For this purpose I've created a IContentRepositoryDescriptor:
[ServiceConfiguration(typeof (IContentRepositoryDescriptor))]
    public class CourtFolderRepositoryDescriptor : ContentRepositoryDescriptorBase
        public CourtFolderRepositoryDescriptor()
        public static string RepositoryKey
            get
                return "YourCourts";
        public override string Key
            get
                return RepositoryKey;
        public override string Name
            get
                return "Court Folders";
        public override IEnumerable Roots
            get
                var courtsAssetFolder = new ContentReference(6);
                var courtShortName = "da";
                var courtAssetFolder = ServiceLocator.Current.GetInstance().GetChildren(courtsAssetFolder)
                    .FirstOrDefault(folder => string.Equals(folder.Name, courtShortName, StringComparison.OrdinalIgnoreCase));
                return new[] { courtAssetFolder.ContentLink };
        public override IEnumerable ContainedTypes
            get
                return new[] { typeof(MediaData), typeof(ContentFolder) };
        public override IEnumerable MainNavigationTypes
            get
                return new[] { typeof(ContentFolder) };
        public override IEnumerable CreatableTypes
            get
and a Component:
[Component]
    public sealed class CourtFolderComponent : ComponentDefinitionBase
        public CourtFolderComponent()
            : base("epi-cms.widget.HierarchicalList")
            Categories = new[] { "content" };
            LanguagePath = "/components/courtfolder";
            SortOrder = 1000;
            PlugInAreas = new[] { PlugInArea.AssetsDefaultGroup };
            Settings.Add(new Setting("repositoryKey", CourtFolderRepositoryDescriptor.RepositoryKey));
The contents of the asset folder returned as root won't load however. Can anybody spot the problem?
Regards,
Bjørn Terje Svennes
#149814
Jun 08, 2016 12:47
I'm having the exact same problem. Did you ever find a solution to this ?
#151067
Jul 11, 2016 1:15
Jul 12, 2016 23:34
Hi. I've been away on holiday so I haven't had the chance to reply. I guess you have found the answer. I fixed the problem by inheriting from MediaComponent instead of ComponentDefinitionBase (and remebering to set the repository key by updating "repositoryKey" and not adding it). But I see now that this wasn't the actual fix. By chance I also changed the repository key to lower case which fits the thread you are linking to.
#151477
Jul 25, 2016 8:01
