Scheduled job log no longer supports HTML?
Ted
Ted
Is it just me, or does the scheduled job log no longer support HTML in the status message?
Screenshot is of a log from Episerver Find with a number of error messages. Normally, these would appear on separate rows, but now we see the actual HTML (
) tags instead:
#149418
May 31, 2016 16:32
You're not alone. Did You find any workaround?
Regards
Gustav
#149420
May 31, 2016 17:24
A temporary workaround is to remove Server.HtmlEncode in DatabaseJob.aspx.
I'll submit a bug report, althought I suspect EPiServer won't view it as a bug.
/Gustav
#149427
May 31, 2016 19:00
Another is to instead generate an html file on disk and then only output the link in summary above. Make sure to consider access rights to logs in that case though :)
#149432
May 31, 2016 23:06
It appears to be an overzealous refactoring. I have created a bug to revert that change; this is the bug number http://world.episerver.com/support/bug-list/bug/CMS-3724 (once it propagates to world).
#149444
Jun 01, 2016 8:58
Ted
Thanks, Ben!
#149447
Jun 01, 2016 10:00
