Hi Anusha,
1. Grzegorz wrote a blog post on how to show additional properties on content creation: https://gregwiechec.com/2015/11/show-additional-properties-on-content-creation/
2. Difficult to tell. Happens sometimes in shared db dev environments (where developer don't have their own DB copy). Does it help if you restart IIS?
3. Yes
I have two optional properties and a required property in the block
[Display(
Order = 10)]
public virtual string Heading { get; set; }
[Required(AllowEmptyStrings = false)]
[Display(
Order = 20)]
public virtual XhtmlString Description { get; set; }
[Display(
Order = 30)]
public virtual Url ButtonLink { get; set; }
and in the view
@Html.PropertyFor(x => x.Heading)
@Html.PropertyFor(x => x.Description)
@Html.PropertyFor(x => x.ButtonLink)
when I tried to create a block in CMS, I could just see the required property 'Description'.
Though the other properties are not mandatory, but I want to see them when I create a block.
Question 1:I could see the optional properties after the block is being created, not sure if it's always the case.
Question 2: If I try to add some content to heading after the block is created, it's throwing an error 'the
insert statement conflicted with the foreign key constraint 'fk_tblWorkContentProperty_tblPropertyDefinition'
the conflict occured in database table tblPropertyDefinition'
Question 3: Is the code written in the view is the right way of rendering the block content?
