Problems publishing pages in CMS (7.5)
Editors suddenly have big problems publishing pages, the auto save almost never works, and publish button not activates...
What could this be a symptom of?
Epi CMS 7.5, on a windows server 2012, Sql Db 2012
Site has been working fine for a year.... no major updates have been made recently.
The error:
-05-13 15:27:15,463 [256] ERROR EPiServer.Global: 1.2.5 Unhandled exception in ASP.NET
System.Web.HttpException (0x80004005): Version is not writeable
at EPiServer.Cms.Shell.UI.Rest.ContentChangeManager.UpdateContentProperties(ContentReference contentReference, IDictionary`2 properties, SaveAction saveAction)
at EPiServer.Cms.Shell.UI.Rest.ContentDataStore.Patch(PatchContentDataModel entity)
at lambda_method(Closure , ControllerBase , Object[] )
at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.b__12()
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation)
at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName)
at EPiServer.Shell.Services.Rest.RestControllerBase.ExecuteCore()
at System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext)
at EPiServer.Shell.Services.Rest.RestHttpHandler.ProcessRequest(HttpContextBase httpContext)
#148475
May 13, 2016 16:58
Do you have any custom properties on pages that has this problem? If you do, try removing them in dev environment and see if that helps. If not, register a support ticket...
#148485
May 14, 2016 6:51
Interesting, I have the same errors, but it happens only from time to time (Epi 9.12)
Custom properties I have are:
- SEOSitemap from Geta
- own implementation of tags tree (similar to categories tree)
But as it happens only sometimes, I would rather think that`s caused by websockets communication being blocked.
#171206
Nov 02, 2016 16:44
