Preview drag and drop
In alloy example when i'm on-page edditing mode i can drag and drop items in content area and there are options for blocks that are available in all-properties mode.
How can i enable this for content areas in new project without alloy downloaded.
Thx
#149423
May 31, 2016 17:53
Alloy does, as far as I recall, use the [AllowedTypes(..)] attribute to restrict the types allowed in Content Areas. It is really simple to add. Episerver's UI will automatically change according to your configuration.
[AllowedTypes(AllowedTypes = new [] { typeof(MyBlockType) })]
public virtual ContentArea ContentArea { get; set; }
More information is available here:
http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/9/Content/Properties/Property-types/Restricting-content-types-in-properties/
Hope that was the answer you were looking for. :-)
Casper Aagaard Rasmussen
#149426
Edited, May 31, 2016 18:53
Sorry my question was not well worded.
So in alloy project when im in "on-page editing" i can also drag and drop stuff into a content area, around content area and change block settings:
Image 1
also i have this options in "all properties" mode:
Image 2
But locally on my empty project i only get block options in "all properties", and in "on-page editing" i can only preview html without changing layout.
Hope i better explained what i whant to have.
Thx
#149437
Jun 01, 2016 7:16
Hi, Nemanja,
Which version are you on? And how do you render the ContentArea on the view, can you share it?
BR,
Marija
#149471
Jun 01, 2016 13:47
ContentAreas should always be rendered via the @Html.PropertyFor(mo..) helper. That ensures that the necessary markup and scripting is applied when you are working in Edit mode.
<div>
    @Html.PropertyFor(model => model.ContentArea)
</div>
It sounds to me like that is what you've left out. Joel Abrahamsson has written a detailed blog post covering the magic behind PropertyFor.
http://joelabrahamsson.com/how-episervers-html-helper-propertyfor-works/
You are highlighting a option called 'Display as: Full' in your screenshot. You can get all the information needed from the Developer Guide covering that exact topic.
http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/8/Rendering/Display-options/Display-options/
Hope that helped.
#149475
Jun 01, 2016 13:53
Hi Marija And Casper,
Caspers aswer worked, i was using displayFor instead of PropertyFor. When i changed it started giving me same options on on-edit as on view all properties !
Thx
#149479
Jun 01, 2016 14:20
