I don't know how to do it with code since I haven't worked with Episerver.Forms, but since they are just blocks, you should be able to uncheck the "Available in edit view" option in Admin.
Excellent, this worked. I tried going about it with code first but without success hehe
Just remember that you will need to do this in all envirnoments(test/stage/prod) so it's better to do it with code, but I don't know how/if it's possible right now.
Yeah thats why i wanted to do it with code in the first place.. but this is better then not being able to disable them at all :)
This should work
var contentTypeRepository = ServiceLocator.Current.GetInstance<IContentTypeRepository>(); var type = contentTypeRepository.Load(typeof(TextareaElementBlock)); type = (ContentType)type.CreateWritableClone(); type.IsAvailable = false; contentTypeRepository.Save(type);
Hi i want to hide default episerver form elements or specific properties on default elements that i dont use in edit mode, any way to go about this?
Best regards Jonas.C
