download pdf with rotativa
I want the html page(content and images) to be converted to pdf.
My view is as below:
Download UrlAsPDF
and the controller as below:
[HttpGet]
public ActionResult UrlAsPDF(ContentReference contentLink)
var url = ServiceLocator.Current.GetInstance();
var pageUrl = url.GetVirtualPath(contentLink);
return new UrlAsPdf(pageUrl.ToString())
FileName = "test.pdf"
I could see the link on my page, when I clicked on it,
I am getting the error as:
Error: Failed loading page http://http//localhost:12345System.Web.Routing.VirtualPathData (sometimes it will work just to ignore this error with --load-error-handling ignore)
Exit with code 1 due to network error: HostNotFoundError
I am running this on my local machine. Are there any other settings I need to look into. the url(http://http//localhost:12345System.Web.Routing.VirtualPathData) seems to be incorrect.
#148772
May 23, 2016 18:50
Use pageUrl.VirtualPath instead of pageUrl.ToString()
#148780
May 24, 2016 8:10
No luck with that. I am getting the 'Error: Failed loading page http://http//localhost:12345testpage/  (sometiems it will work just to ignore this error with load-error-handling ignore)
Exit with code 1 due to network error: HostNotFoundError'
The url seems to be wrong. We can't have two http and there is no slash after the port number and pagetype.
#148787
May 24, 2016 11:02
Ah.
Instead of using .GetVirtualPath, use
GetUrl(new UrlBuilder(contentLink), ContextMode.Default);
#148790
May 24, 2016 11:36
