Disable Simple Address
Hello.
Is there a way to disable Simple Address from CMS (Version 9.3.3)?
I found in some topics something like add a configuration under Episerver tag in web.config
However it didn't worked for me. The field still exists in the CMS Editor. I presume urlRewrite doesn't exists on version 9 (refering to http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/9/Configuration/Configuring-episerver/)
Thanks in advance
Antonio Costa
#149291
May 27, 2016 16:55
Hello Antonio is your requirement simply to hide the simple address in the editor UI?
#149293
May 27, 2016 17:09
If this is the case then you can hide the simple URL with the following code:
[EditorDescriptorRegistration(TargetType = typeof(ContentData))]
public class RestrictedUserEditorDescriptor : EditorDescriptor
        foreach (ExtendedMetadata property in metadata.Properties)
            if (property.PropertyName == "PageExternalURL")
                property.ShowForEdit = false;
#149294
Edited, May 27, 2016 17:21
Hi David. Thanks for your reply.
My requirement is to disable the functionality.
With your solution I'm just hiding the field, right?
Where can I add the config to disable it?
Thank you.
#149295
Edited, May 27, 2016 17:22
Hello Antionio by hiding the field editors can't create simple URLs so it is effectively disabled.
Is there a specific reason why you need to disable the functionality rather than just stop editors from using it?
I'm not sure if its possible to disable it in config.
David
#149299
May 27, 2016 17:36
Simple address handling is registered as a separate route in RouteCollection.Routes. So you can override RegisterRoutes in global.asax.cs and there first  call base.RegisterRoutes and then afterwards remove the ContentRoute that is named "simpleaddress" from RouteCollection.Routes.
#149334
May 30, 2016 9:56
