How to avoid duplicates of contents in a ContentArea
Is there an easy way to avoid duplicates in the ContentArea?
Have searched but not found much.... I prefer not to hook up in publish event att do the check myself..
Attribute like [DisableDuplicates] would have been perfect here
#147526
Apr 18, 2016 10:49
How about creating a custom validator for this? You could either give a warning or an error message to the editors.
http://henrikm.com/custom-episerver-property-validation/
#147528
Apr 18, 2016 11:01
Yes, I tried it and it works perfectly!!
Thanks a lot, this made my day :)
A minor thing... would be great to be able to present the actual proprerty display name to the editor (and not the actual property name)...
#147529
Apr 18, 2016 11:27
Great!
Regarding the display name, you could check out Grzegorz answer in this forum thread: http://world.episerver.com/forum/developer-forum/Developer-to-developer/Thread-Container/2015/8/localized-property-name-in-validation/
#147530
Apr 18, 2016 11:48
Yes I found his answer and borrowed it :-)
Here is the code if anyone is interested, not many rows
[AttributeUsage(AttributeTargets.Property | AttributeTargets.Field, AllowMultiple = false)]
	public sealed class DisableDuplicates : ValidationAttribute
		protected override ValidationResult IsValid(object value, ValidationContext validationContext)
			var propertyDefinitionRepository = EPiServer.ServiceLocation.ServiceLocator.Current.GetInstance<IPropertyDefinitionRepository>();
			var propertyDefinitionId = ((PageData)validationContext.ObjectInstance).Property[validationContext.MemberName].PropertyDefinitionID;
			var propertyDefinition = propertyDefinitionRepository.Load(propertyDefinitionId);
			propertyDefinition.LocalizationService = LocalizationService.Current;
			if (IsDuplicate(value as ContentArea))
				return new ValidationResult(
					$"You can not have duplicate content in: '{propertyDefinition.TranslateDisplayName()}'",
					new[] { validationContext.MemberName });
			return ValidationResult.Success;
		bool IsDuplicate(ContentArea area)
			if (area == null || area.IsEmpty)
				return false;
			if (area.Items == null || area.Items.Any() == false)
				return false;
			List<int> items = new List<int>();
			foreach (var cai in area.Items)
				if (items.Contains(cai.ContentLink.ID))
					return true;
				items.Add(cai.ContentLink.ID);
			return false;
#147531
Apr 18, 2016 11:49
Thanks for sharing! :-)
#147534
Apr 18, 2016 11:53
Sounds like a good solution. I might steal it :)
#147537
Apr 18, 2016 12:10
You could also simplify IsDuplicate method to single line expression :)
private bool IsDuplicate(ContentArea area)
    return area?.Items.DistinctBy(c => c.ContentLink.ToReferenceWithoutVersion()).Count() != area?.Items.Count;
#147545
Apr 18, 2016 13:24
Excellent!
#147548
Apr 18, 2016 13:44
