Sounds like IIS timeout rather than database...
Tried to increase timeout on requests?
system.web>
<httpRuntime executionTimeout="180" />
</system.web>
Set it to an hour or so temporarily...
All,
I am attempting to import data from one epi instance to another. This is a multisite so I'm only attempting to move one "site" over. The size of the export is 900MB. I've already run into the maxAllowed setting that I had to bump up in IIS. But now when I attempt to import the file I get a timeout error while episerver admin screen.
Here is a snippet of the error log:
2016-04-21 21:18:19,010 [62] ERROR EPiServer.Global: 1.2.5 Unhandled exception in ASP.NET
System.Web.HttpException (0x80004005): Request timed out.
I am hoping someone can give me insight in modifying the connection timeout. I've already modified the web.config connection string property to use 600 seconds and nothing. Is there anything else to try or some other setting to update?
Thank you,
Steve
