Content Collaboration - can't comment, but no errors in console
Hi, I have installed content collaboration in an Intranet project using Owin.
That means I already have a startup class, so I included to it this part:
            var configuration = new HubConfiguration
                EnableJSONP = true,
                EnableDetailedErrors = true
            app.MapSignalR(configuration);
(copied from disassembled ContentCollaborationOWINStartup). (I have also tried not to do that, but to switch the startup class in web.config, then to switch back to mine)
My site is hosted on Azure, so I can't clear temporary files, but I've deployed directly from VS using "Remove additional files at destination" (which should be clearing temp files).
This is how my console looks like when I refresh the edit mode:
http://prntscr.com/ap7biw
And this is the additional console logging when I try to post a comment:
http://prntscr.com/ap7bsr
No errors in the log file when trying to post the comment.
Any ideas what else I can do to figure out what's wrong?
#147195
Apr 07, 2016 11:58
Hi Marija
Did you resolve your issue? I'm trying to achieve the same thing - I tried this:
new EPiServer.ContentCollaboration.SignalR.ContentCollaborationOWINStartup().Configuration(app);
But I have the same issue as you.
Tim
#151381
Jul 19, 2016 11:21
Hi, Tim,
It seems that the order of registration fixed the particular issue with commenting for me - I got the fix from Epi support, they advised me to move the mapping of signalr after setting up Owin authentication.
That all seems to work fine, however, I could still stumble upon issues with notifications and I had to rewrite Owin membership/role provider not to use HTTP context, since CC calls GetAllUsers.
Even then, I got a new issue which occurred sometimes (doh) on any of the environments, I couldn't spot the pattern. http://world.episerver.com/forum/developer-forum/-Episerver-75-CMS/Thread-Container/2016/6/notification-settings-for-content-collaboration-don39t-work/
Eventually, the client agreed that we shouldn't put more time to it and that we should switch to Projects.
BR,
Marija
#151452
Jul 22, 2016 9:23
Hi Marija
Thanks for your response it was very helpful and helped identify my issue. It was in fact the following line:
new EPiServer.ServiceApi.Startup().Configuration(app);
For some reason this breaks content collaboration commenting functionality. I don't think I'm using the service API so have just commented it out.
Tim
#151453
Jul 22, 2016 9:55
