SEO-friendly routing
I have a product details page in a standard (non-Commerce) EPiServer MVC site. The controller for the page populates the details using a query string parameter, so the URL looks like www.mysite.com/container/product?productId=ABC123 ('container' is an intermediate page in the hierarchy, which also shows content).
I want to add routing so that the URL www.mysite.com/container/product/ABC123 is routed to the correct controller, and the product ID is passed to the controller.
I've tried partial routing, but this doesn't seem the right approach - I don't really want to relocate the page,just pass it a parameter from the route.
I've also tried using custom segments, but I'm not sure how the URL shoudl be defined in this case.
Whichever approach I try, I'm currently getting either 404's or redirect loops.
I'm sure this shouldn't be that difficult - any ideas anyone?
Thanks, Mark
#146887
Mar 29, 2016 21:41
Setting up your route something like this might work, assuming you controller is named ProductPageController and that you don't use /product/ in other url:s on the site
RouteTable.Routes.MapEnterpriseRoutes(
	 url: "{language}/{node}/product/{productId}/{page}/{action}",
	 defaults: new { controller = "ProductPage", action = "ShowProduct", searchTerm = UrlParameter.Optional, page = UrlParameter.Optional }
And then you can add a ShowProduct method in you controller and retrive the id and load the correct view
public ViewResult ShowProduct(JobPage currentPage, string productId) {
	throw new NotImplementedException("load view for product " + productId);
#146912
Mar 30, 2016 16:34
Using IPartialRouter should work and it has the benefit of not needing to find a pattern or reserve the phrase "product" in the URL as long as have specific page type for this.
Can you post the code you were trying with?
#146964
Mar 31, 2016 21:13
Johan,
Thanks for the tip - I ended up implementing a custom segment.
I was wondering about IPartial router, but the signature for the interface(IPartialRouter<T1, T2>) didn't seem right - although I hadn't tried it with T! the same type as T2.
#146971
Apr 01, 2016 9:51
