Mogul SEO Manager Robot.txt & SiteMap
I am planning to use Mogul SEO Manager for SEO. I am using EPiServer CMS version 9 based on Azure Cloud.
Does Mogul SEO Manager supports Azure Cloud.
How can I implement SEO manager's SiteMap in MVC pattern?
How can I implement Robots.txt in Mogul SEO Manager?
Anyone's help is appreciated.
Thanks in advance.
Regards,
Sanket Mahimkar.
#145406
Mar 03, 2016 10:46
Hi Sanket, this link might have answers to your question?
http://www.mogul.com/en/what-we-do/products/seo-manager/help
Have a nice day!
/R
#145415
Mar 03, 2016 13:00
I installed SEO Manger nuget. For sitemap, I got a URL "www.example.com/MogulSEOManagerSitemap.aspx"
Normally sitemap URL looks like "www.example.com/sitemap.xml".
How can I make "www.example.com/MogulSEOManagerSitemap.aspx" to "www.example.com/sitemap.xml"?
Thanks & Regards,
Sanket Mahimkar
#145485
Mar 04, 2016 12:32
Hello Sanket
This is your best approach for managing robots.txt in Episerver: http://nuget.episerver.com/en/OtherPages/Package/?packageId=POSSIBLE.RobotsTxtHandler
David
#145489
Mar 04, 2016 13:36
Thanks David for your answer.
Actually I have developed Robot.txt handler.
My question is about sitemap in Mogul SEO manager, Mogul provides sitemap as "www.example.com/MogulSEOManagerSitemap.aspx".
Regards,
Sanket Mahimkar
#145491
Mar 04, 2016 14:07
I seem to recall that I used to set it in Google webmaster tools to use that aspx. Is that enough solution for you?
And get in touch with Mogul Service desk if you got any other questions and they will help you out...
#145501
Edited, Mar 04, 2016 15:40
<p>Hi,</p> <p></p> <p>Thanks for the reply.</p> <p></p> <p>Could you please give more information on how you done that using&nbsp;<span>Google webmaster tools? It will be helpful for me as I dont have much time for making R&amp;D over that.</span></p> <p><span></span></p> <p><span>Thanks in advance.</span></p> <p><span></span></p> <p><span>Best Regards,</span></p> <p><span>Sanket Mahimkar</span></p>
#145603
Mar 08, 2016 9:32
In google webmaster tools you have a menu item in left menu called crawl => sitemap =>click button for add sitemap.
Add the MogulSeoManagerSitemap.aspx there...
#145674
Edited, Mar 09, 2016 16:40
<p>Hi, you should also be able advertise the mogul sitemap url in robots.txt in "sitemap" element</p> <p></p> <p>https://developers.google.com/webmasters/control-crawl-index/docs/robots_txt</p> <p></p> <p>Quote:</p> <p></p> <h3>sitemap</h3> <p>Supported by Google, Ask, Bing, Yahoo; defined on&nbsp;<a href="http://sitemaps.org/">sitemaps.org</a>.</p> <p>Usage:</p> <pre>sitemap: [absoluteURL] </pre> <p>[absoluteURL] points to a Sitemap, Sitemap Index file or equivalent URL. The URL does not have to be on the same host as the robots.txt file. Multiple&nbsp;<code>sitemap</code>&nbsp;entries may exist. As non-group-member records, these are not tied to any specific user-agents and may be followed by all crawlers, provided it is not disallowed.</p>
#150283
Jun 15, 2016 13:50
Totally right @Janne Kuusela!
I was going to update documentation for SEO Manager with that but it actually already existed here
#150286
Edited, Jun 15, 2016 14:03
