EPiServer Thumbnails
I have an odd question in regards to episerver thumbnailmanager.  We extended episerver thumbnailer to generate the thumbnails a bit differently but appears that EPiServer has made the chose to save all thumbnails as png.  I might be wrong on that but it appears in all cases regardless of my image mimetype, it is saving as a png.  Is there a way around this or an update that we could try to save the thumbnails as the correct mimetype.  Thank you.
Joshua
#146879
Mar 29, 2016 16:27
How are you specifying the path to the thumbnail image in your model?
#146891
Mar 30, 2016 9:13
Markiemark
I just wrote a small blog post about it.
It was a little experiment I did a while ago.
Not production ready code, but it will get you started
#146907
Mar 30, 2016 15:19
Thanks for the write up Mark.  The initialization module was the trick to make it all work as normal so again, thank you and arild for helping me out.
#146955
Mar 31, 2016 15:25
