Content provider
After upgrading to 9.4.2 Episerver.Cms.UI package does not work conten view mode for custom provider. Content provider was made with the help of articles
http://world.episerver.com/blogs/Per-Magne-Skuseth/Dates/2014/11/content-providers-101--part-i-introduction-initialization-ui--identity-mapping/
before  upgrading
after  upgrading
Natallia
#146801
Mar 24, 2016 18:51
Did you try to turn on websocket on your server?
/Q
#146802
Mar 24, 2016 20:05
Hi Quan Mai
I tried to include websocket, but to no avail. Problem still exists
#146807
Mar 25, 2016 15:26
Any errors in browser console?
/Q
#146819
Mar 27, 2016 10:44
no errors
#146826
Mar 28, 2016 14:33
Hi, we have the same issue with latest version.
Has anyone found a workaround?
#146972
Apr 01, 2016 10:01
I've filed a support case now.
#146984
Apr 01, 2016 12:49
Hi Marija
Was there any response from support?
#147006
Apr 04, 2016 9:15
Hi, my co-worker solved it.
The issue is that projects js file throws an exception (which is unfortunately not visible in the console) if work ID is 0 (although Projects aren't even enabled from Admin mode!).
So, my colleague added a fake version ID and set the version in the provider:
        public override IContentVersionRepository VersionRepository
            get
                return (this._myContentVersionStore ?? (this._myContentVersionStore = new MyContentVersionStore(this)));
I believe this should be fixed, I'll write to support to inform them and I'll let you know if there is a better workaround.
BR,
Marija
#147008
Apr 04, 2016 10:19
I've got the info that a bug has been reported:
"CMS-3219 Issue with projects UI code and Content providers"
Our fix works so-so, it looks like it stops working after a while (?!). If my colleague fixes this, I'll keep you posted.
#147017
Apr 04, 2016 14:53
Marija, thanks for the help.
#147067
Apr 05, 2016 16:40
As a temporary fix for this I extracted "~/modules/_protected/CMS/CMS.zip" and updated the if-statement in "9.4.2.0/ClientResources/epi-cms/widgets.js" (in the method 'getProjectItemForContent', line 199, col 932) from:
if(_736.workId===0)
to:
if(_736.workId===0 && (_736.providerName === null || _736.providerName === ''))
Finally I just deleted CMS.zip and created a new one from my extracted files.
#147105
Edited, Apr 06, 2016 11:16
