Cache invalidation in load balanced environment
Hi All,
I aSubmitm just in process of preparing the production enviroment. There are 2 web servers behind the load balancer. In order to improve performance, ISynchronizedObjectInstanceCache is used in multiple places. Cache eviction policy is set to DataFactoryCache.VersionKey. However, if I change the content on one node, changes are not being persised to the scond server. As per documentation (http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/9/Deployment/Deployment-scenarios/Deploying-to-Windows-Servers/) I enabled Remote Events by pasting in endpoint configuarion.
I am sure there is something I must have missed :(
Many thanks,
M
[Pasting files is not allowed]
#145602
Mar 08, 2016 9:10
Can you turn on logging to verify that the event are received (firewall/port is open)?
#145612
Mar 08, 2016 10:28
Remote event listener is a useful tool for testing if events are received by the server!
#145825
Mar 14, 2016 0:15
Are you running udp or tcp?
I have been in a couple of situations where udp were not possible to use.
#145827
Mar 14, 2016 6:18
Make sure in application pool settings maximum worker processe is set to 1 also try pinging the replication url port and url if they are working as expected from both servers in NLB.
#145849
Mar 14, 2016 11:58
" In order to improve performance, ISynchronizedObjectInstanceCache is used in multiple places."
Not sure how did you implement it, but note that the default implemenation of ISynchronizedObjectInstanceCache only ensure the synchronization of cache removal. So if you have a cache in both server A and B, then you update the cache in server A, the cache in server B will be removed but there is no guarantee that it will have the new cache in server B.
Regards.
/Q
#145850
Edited, Mar 14, 2016 12:05
