Block is null in BlockController (Epi 9)
Hi.
This is our defined block type:
namespace Project.EPiServer.Blocks
    [ContentType(DisplayName = "Rad", GUID = "5090aae4-c0e6-43fd-8bcd-f2507d01972a")]
    public class RowBlock : BlockData
        [Display(Name = "Promo elements", Order = 10)]
        [AllowedTypes(AllowedTypes = new Type[] { typeof(PromoBlock) })]
        public virtual ContentArea Blocks { get; set; }
And this is our block controller:
namespace Project.Web.Controllers
    public class RowBlockController : BlockController
        public override ActionResult Index(RowBlock block)
            return PartialView("...");
The problem is that the block parameter to the Index method is null.
Everything works fine when I have a view named "RowBlock" (i.e. without a controller), but when we introduce a controller the block is null. Any suggestions to why this might be?
Thank you.
#146325
Mar 16, 2016 10:26
#146326
Mar 16, 2016 10:28
I think the problem is the name of the parameter (block). If I remember correctly it has to be called either currentContent or currentBlock. That is because the model binding is looking for a parameter called that to bind the model to.
Regards
Per Gunsarfs
#146384
Mar 16, 2016 10:56
You are completely correct, Per! Thank you very much for the response.
#146504
Mar 16, 2016 16:42
Ha ha, had the same issue with pages, this is the list of working parameter names:
http://www.mogul.com/en/about-mogul/blog/sniff-page-parameter-in-my-controller-is-null
#146960
Mar 31, 2016 16:23
