XForms Add Dynamic Field
Scott Reed
Scott Reed
OMVPPaaS CMS Developer Certificationworkspace_premiumOpal Administrator CertificationOpal Tools Certification
Hi all,
Does anyone know if it's possible in the XForm processing to add a new field in to be handled via any actions. E.g. we have the method
        [AcceptVerbs(HttpVerbs.Post)]
        public virtual ActionResult XFormSuccess(XFormPostedData xFormPostedData)
Which is used to do some custom process. But I want to add a value that needs to be saved coming from a property set on the block that the form is housed in. The property looks up some other data for Marketo that needs to be handled by the form actions.
Scott
#144897
Feb 22, 2016 12:13
Scott Reed
It's fine I managed to reverse engineer it all in ILSpy and overrode the ProcessXFormAction in our custom version of the XFormPageUnknownActionHandler. I was able to directly modify the XML data and this is pushed through to the marketo connetor as I wanted :-)
#144900
Feb 22, 2016 13:34
