Might be this bug...
http://world.episerver.com/support/Bug-list/bug/103642
In that case, upgrading to EPiServer.CMS.UI 7.8.0 will fix the issue...might be worth trying before starting to customize anything.
Thank you for your answer. We have already passed V.7.8 and are currently running version 7.19 and this still isnt fixed.
I might try to customize this or upgrade to major release 9 so i can use Episerver forms :)
Upgrading from 7.5 and up is pretty smooth and working with v9 is really great so I would definitely recommend it to avoid a lot of similar "features". v9 doesn't have tons of new features but it's smoother, faster and easier to work with.
Hello!
After upgrading to episerver 7.5 xform inputs like textarea and textbox does not recieve any CSS classes for errors after post. Also the error validation text related to the input does not render right below the input anymore but rather on a new row to the far left, i suspect this is because CSS classes are missing for the inputs.
here is a link with a picture showing my Xform after post:
http://tinypic.com/r/30dcmcp/9
Is there any way i can make Xform add CSS validaton for my inputs again without creating a custom CSS validation in Xform?
