Navigate to login page when we logout
I want to naviagate to login page when i logout . Is there any way to do it in web.config or global.asax
#144766
Feb 18, 2016 15:02
If you're talking about the built-in Logout functionality when you're logged in to edit/admin mode, you could rewrite the logout route handler and append a redirect to your login page.
Alf has an example of it here: http://talk.alfnilsson.se/2014/01/29/hooking-up-to-the-episerver-quicknavigator/
If you're talking about a custom Logout button that you have in your templates somewhere, you could just add a redirect in your controller when that button is clicked.
#144775
Feb 18, 2016 16:02
No i was talking default episerver logout. It has navigate to my custom login page after logging out.
#144778
Edited, Feb 18, 2016 16:17
Unless you want to have one login page for logout, and one login page for first-time login, you can change the loginUrl in web.config
Or do you want to have 2 login pages?
#144782
Feb 18, 2016 16:51
<add url="~/util/logout.aspx" mappedUrl="~/Login?ReturnUrl=/" />
I was using this to map url
and in controller
public ActionResult Login()
FormsAuthentication.SignOut();
return View(string.Format("~/Views/StartPage/Login.cshtml"));
i am doing this in PageControllerBase class but it doesnt load the css at all in the page
#144783
Feb 18, 2016 17:31
Personally I'd use the IIS url rewrite module to redirect "/Util/logout.aspx" to your login page.
#144785
Edited, Feb 18, 2016 17:33
