Available as zip files for download (up until version 7.5), and NuGet package for upgrading of an existing installation.A first-time installation can only be done for CMS 7.5 through Deployment Center. To have Mail with the latest Episerver version, install a CMS 7.5 site with Mail, and then upgrade to the latest through NuGet.
So says the documentation at least. Nasty. Probably work in progress to support latest version I guess. Maybe someone from episerver can give an ETA?
And if you have the possibility I would recommend not start building anything on Community today. At least if you only need minor parts of it. My most personal impression is that they are reworking that part.I would custom build those parts of the solution if possible based on the much more polished CMS 😀
That's my personal opinion though. At least check with episerver before you start a major community project and ask for advice.
Hello..i am trying to install community 7.5 in Episerver 9 project (by replacing the old Episerver.dll [version 7.5]). But I am getting below this error
Started a transacted install
productPath: C:\Program Files (x86)\EPiServer\Framework\7.5.394.2\
installedVersion: 9.6.1.0
frameworkVersion: 7.5.394.2
AppData path: C:\Users\Dipak\Desktop\EPiServer 9 Project\Episerver9withCommunit
y\Community
Skipping web config modification of EPiServer Framework (6.0.318.113 < 9.6.1.0)
Skipping web config modification of EPiServer Framework (6.1.79.0 < 9.6.1.0)
Skipping web config modification of EPiServer Framework (6.2.267.1 < 9.6.1.0)
Skipping web config modification of EPiServer Framework (7.5.394.2 < 9.6.1.0)
Removing assembly redirect for EPiServer.Shell.UI
Copying C:\Program Files (x86)\EPiServer\CommonFramework\7.5.394.2\bin to C:\Users\Dipak\Desktop\EPiServer 9 Project\Episerver9withCommunity\Episerver9withCommunity\bin
Copying C:\Program Files (x86)\EPiServer\CommonFramework\7.5.394.2\Application\lang to C:\Users\Dipak\Desktop\EPiServer 9 Project\Episerver9withCommunity\Episerver9withCommunity\lang
Adding/Updating assembly redirect for EPiServer.Common.Cache
Adding/Updating assembly redirect for EPiServer.Common.ComponentArt.Web.UI
Adding/Updating assembly redirect for EPiServer.Common.Configuration
Adding/Updating assembly redirect for EPiServer.Common.Criteria
Adding/Updating assembly redirect for EPiServer.Common.Data
Adding/Updating assembly redirect for EPiServer.Common.EventCounter
Adding/Updating assembly redirect for EPiServer.Common.Framework
Adding/Updating assembly redirect for EPiServer.Common.Framework.Exceptions
Adding/Updating assembly redirect for EPiServer.Common.Framework.Impl
Adding/Updating assembly redirect for EPiServer.Common.Security
Adding/Updating assembly redirect for EPiServer.Common.Web.Authorization
Adding/Updating assembly redirect for EPiServer.Common.Web.Authorization.Multiplexing
Copying C:\Program Files (x86)\EPiServer\Community\7.5.394.2\Bin to C:\Users\Dipak\Desktop\EPiServer 9 Project\Episerver9withCommunity\Episerver9withCommunity\bin
Copying C:\Program Files (x86)\EPiServer\Community\7.5.394.2\Application to C:\Users\Dipak\Desktop\EPiServer 9 Project\Episerver9withCommunity\Episerver9withCommunity
CommunityAdmins,CommunityModerators,Administrators
Adding/Updating assembly redirect for EPiServer.Community.Administration
Adding/Updating assembly redirect for EPiServer.Community.Blog
Adding/Updating assembly redirect for EPiServer.Community.Calendar
Adding/Updating assembly redirect for EPiServer.Community.Chat
Adding/Updating assembly redirect for EPiServer.Community.Chat.XmlSerializers
Adding/Updating assembly redirect for EPiServer.Community.Club
Adding/Updating assembly redirect for EPiServer.Community.Configuration
Adding/Updating assembly redirect for EPiServer.Community.Contact
Adding/Updating assembly redirect for EPiServer.Community.Contest
Adding/Updating assembly redirect for EPiServer.Community.DirectMessage
Adding/Updating assembly redirect for EPiServer.Community.DocumentArchive
Adding/Updating assembly redirect for EPiServer.Community.Expert
Adding/Updating assembly redirect for EPiServer.Community.Forum
Adding/Updating assembly redirect for EPiServer.Community.Gadgets
Adding/Updating assembly redirect for EPiServer.Community.ImageGallery
Adding/Updating assembly redirect for EPiServer.Community.Licensing
Adding/Updating assembly redirect for EPiServer.Community.MyPage
Adding/Updating assembly redirect for EPiServer.Community.NewsFeed
Adding/Updating assembly redirect for EPiServer.Community.NML
Adding/Updating assembly redirect for EPiServer.Community.OnlineStatus
Adding/Updating assembly redirect for EPiServer.Community.Poll
Adding/Updating assembly redirect for EPiServer.Community.Search
Adding/Updating assembly redirect for EPiServer.Community.StarViral
Adding/Updating assembly redirect for EPiServer.Community.VideoGallery
Adding/Updating assembly redirect for EPiServer.Community.VideoGallery.XmlSerializers
Adding/Updating assembly redirect for EPiServer.Community.Wcf.Blog
Adding/Updating assembly redirect for EPiServer.Community.Wcf.Feed
Adding/Updating assembly redirect for EPiServer.Community.Web.Administration
Adding/Updating assembly redirect for EPiServer.Community.Webmail
Adding/Updating assembly redirect for EPiServer.Community.Webmail.XmlSerializers
Mime type (.xap, application/x-silverlight-app) already exists.
The database login password generated is qJ2457-5
An unhandled error has occured:
The argument is null or empty. Provide an argument that is not null or empty,
and then try the command again.
When executing
At C:\Program Files (x86)\EPiServer\Community\7.5.394.2\Install\System Scripts\
Install Database (SqlServer).ps1:171 char:13
+ -UserName $properties.Database.ProductDatabaseLoginName `
An error has occured and the transaction will be rolled back
Rolledback
When executing
Get-EPiIsBulkInstalling
At C:\Program Files (x86)\EPiServer\Community\7.5.394.2\Install\System Scripts\Install Database (SqlServer).ps1:171 char:13
System.Management.Automation.ParentContainsErrorRecordException: Cannot validate argument on parameter 'UserName'. The argument is null or empty. Provide an argument that is not null or empty, and then try the command again.
Could you please help me out?
Regards
Dipak
I am not able to install EPiMail and Communtiy in my existing site which I have build in EPiServer 9.
I am not able to select my existing site from deployment center. Could you please help me out?
Regards
