Find page an asset is on
Is there a way in c# to find the page(s) that a certain asset such as an image is on albeit a page or block on a page. Ideally I would like an asset search library and allows the user to click on the a link that will take them to the image on the page.
Jon
#144998
Feb 23, 2016 16:20
Check out softlink class in api to get references.
http://world.episerver.com/documentation/Class-library/?documentId=cms/8/2244434
#145002
Feb 23, 2016 16:44
That will give you a list of softlinks that contain pagelink as property. Use UrlResolver to get the url from that...
#145003
Feb 23, 2016 16:47
Hi Jonathan,
If you're using the latest version of EPiServer CMS, you can try the following code:
var contentRepository = ServiceLocator.Current.GetInstance<IContentRepository>();
var content = contentRepository.Get<ImageData>(new ContentReference(87));
var references = contentRepository.GetReferencesToContent(content.ContentLink, true).ToList();
I used IContentSoftLinkRepository for Blocks and Pages, but it doesn't return correct results for Assets.
#145008
Feb 23, 2016 18:11
Great - but how would you dynamically know what Data Type the asset is? For example Video, Pdf, Image etc for this bit of the code: var content = contentRepository.Get<???>(new ContentReference(87));
#145009
Feb 23, 2016 18:18
You can fetch the content as IContent
#145018
Feb 23, 2016 19:28
.Get<MediaData>(mediaReference) as Image data
Or
.Get<MediaData>(mediaReference).MimeType
are two ways to get what type of media content you get...or use IContent like Dejan says if you don't even know if it is media.
#145020
Feb 23, 2016 21:18
Hi, These are all great replies and work - unfortunately it is very slow as I have lots of assets and lots of pages - it takes about 1 minute to get all the data back.
I think ill give this idea a miss - but thanks for all your help guys,
Jon
#145079
Feb 24, 2016 10:54
