EPIServer editor logout customize
How can i customize the EPIServer editor logout to my customized route (URL). Bascially i want to change the /util/logout.aspx to different route.
#144339
Feb 11, 2016 9:01
Map it using the vpp should work. Tried custom route?
#144340
Feb 11, 2016 9:06
Check out example for custom route here at the bottom
http://talk.alfnilsson.se/category/extending-episerver/
#144345
Feb 11, 2016 9:42
For older sites I used this approach with virtual path mappings to override EPiServer default pages.
https://www.epinova.no/en/blog/virtual-path-registration-tip/
Don't customomize the actual logout.aspx however. To tricky to upgrade then :)
#144351
Feb 11, 2016 11:15
