Create new Textbox CMS Widget
I have a page in the CMS that requires either 1,2,3 or more textboxes but nothing is set in stone to the actual amount needed so I was wondering if there is a way that I could create my own Widget?
For example it starts off with one Textbox but if the user wants another textbox they could click ADD and a new textbox appears. The data could be stored in a List.
Any ideas if this is possible?
Jon
#144152
Feb 08, 2016 16:30
You mean for the end user or for an editor in edit mode?
#144158
Feb 08, 2016 17:23
Maybe you could use list property with just one Text field? Then there will be no custom development.
http://world.episerver.com/blogs/Per-Magne-Skuseth/Dates/2015/11/trying-out-propertylistt/
#144176
Feb 08, 2016 20:55
Depending what you need it for, categories might be a solution too...
Custom property is your other bet of course.
If you think that you might need more data than simple strings later it might be worth adding a separate content type for them.
#144178
Feb 08, 2016 22:53
Hi All,
Yes it is for the Admin user in the CMS.
Jon
#144197
Feb 09, 2016 9:10
