My best guess is that it's waiting for an update to complete but times out...
Might work to just hit it a few times :)
I would dotPeek that method and see if I could increase timeout. If that doesn't work, so each step manually I guess.
There is a 5 minute command timeout in GetDatabaseVersion. In this method it only gets the current schema version but failing at that step with exception -2 which is command timeout.
Hi All
I'm currently upgrading to episerver 9 using automatica database schema - it all works like a charm in dev machines . However it is failing on larger database size (copy of prod) while upgrading db schema with the following error
Any ideas before I take the manual db update route?
Could not read database schema version. There is likely an ongoing update of the database.
Exception Details: System.Data.DataException: Could not read database schema version. There is likely an ongoing update of the database.
Source Error:
Kashif
