You should check out the CRM addon
http://world.episerver.com/add-ons/connect-for-crm/
Might need some work though since they seem to have support up to episerver 7
Shouldn't be too much work to make it support episerver 9 since 7 to 9 is pretty similar.
Thanks for that, yeah I went through with the install and it seems to work when connecting to on-premise CRM, however, I haven't had much luck with CRM Online, my credentials keep getting declined, maybe there's some configuration on the CRM Online side, would you happen to know?
Regards
Havn't tried the online version sorry. Hopefully someone else have...
For future reference - the correct URL for the Dynamics CRM add-on for Epi9 is http://world.episerver.com/add-ons/connect-for-marketing-automation/
The add-on is now a general multi-vendor connector just called "Connect for Marketing Automation".
I can't find any info to back this up, but I would guess that only the standalone version of Dynamics CRM is supported (not online).
Is there a connector available for Episerver CMS 9 that can connect to Microsoft Dynamics CRM Online?
Regards
