You didn't get the Appdata folder that contains all the blobs / addon files...?
That's my best guess
Hi, and thanks for your comment.
It could be yes, but why should that prevent me from going to edit mode?
Addon for image vault is in edit mode. If that crashes hard it's not too strange...
Just speculating though :) I would grab a fresh appdata folder when taking a database backup from working server and restore that locally.
Might as well do a winmerge compare of files to see if some developer messed up along the way and didn't check in everything. That's not too uncommon either unfortunately :)
I am trying to access Edit mode in EPiServer CMS.. I think it may be caused by ImageVault but I am not sure..
So when I am pressing the "Edit mode" button, the button is clicked and I receive alot of console errors:
Javascript:
dojo/parser::parse() error Error: No store by the name 'imagevault.categorystore' exists.(…)(anonymous function) @ widgets.js:2
widgets.js:2 TypeError: Cannot read property 'id' of undefined
at declare.startup (ImageVault.AddOn.EPiCMS7/4.5.2/ClientResources/Scripts/components/ImageVaultBrowser.js:92)
at widgets.js:2
at Object._172.forEach (dojo.js:15)
at _68.startup (widgets.js:2)
at _19e (dojo.js:15)
at _6b3.startup (widgets.js:2)
at _10f3.startup (widgets.js:2)
at widgets.js:2
at Object._172.forEach (dojo.js:15)(anonymous function) @ widgets.js:2
at widgets.js:2
at widgets.js:2
widgets.js:2 Uncaught TypeError: Cannot read property 'getChildren' of undefined
I receive following error when pressing on "edit mode"
2016-02-11 15:09:21,360 [13] ERROR EPiServer.Global: 1.2.5 Unhandled exception in ASP.NET
System.IO.FileNotFoundException: Could not find file 'C:\Projects\ProjectName.New.Web\Main\AppData\blobs\e5e38d3d27c6413b860804804dfd6dc9\90b2dde8690e48d1b7009bf3b7ed91f5.jpg'.
File name: 'C:\Projects\ProjectName.Web\Main\AppData\blobs\e5e38d3d27c6413b860804804dfd6dc9\90b2dde8690e48d1b7009bf3b7ed91f5.jpg'
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Web.HttpResponse.TransmitFile(String filename, Int64 offset, Int64 length)
at System.Web.HttpResponseWrapper.TransmitFile(String filename)
at EPiServer.Web.BlobHttpHandler.ProcessRequestAsyncInternal(HttpContextWrapper context, AsyncCallback cb, Object extraData)
Good to know:
I just received this project from TFS. However I am not 100% sure of the Imagevault connection is working. and if I somehow need to put the VPP folder in the correct folder?
Do you have any ideas?
