Use own urlresolver?
Is it even possible to override EPiServer UrlResolver?
I get an error message saying "Only concrete types can be built by ConstructorInstance"
Anyone done this?
/Jens
#173418
Dec 23, 2016 10:20
Hi Jens,
Yes, it is possible.
EPiServer.Web.Routing.UrlResolver is an abstract class, and episerver's default implementation is EPiServer.Web.Routing.Internal.DefaultUrlResolver.
That class is decorated with ServiceConfiguration attribute like this:
[ServiceConfiguration(Lifecycle = ServiceInstanceScope.Singleton, ServiceType = typeof (UrlResolver))]
public class DefaultUrlResolver : UrlResolver
You can create your own implementation
public class MyUrlResolver : UrlResolver
And tell EPiServer to use your implementation like this:
[ModuleDependency(typeof(ServiceContainerInitialization))]
public class MyUrlResolverInitModule : IConfigurableModule
        context.Container.Configure(
            x =>
                x.For<UrlResolver>().Singleton().Use<MyUrlResolver>();
Implementing all UrlResolver's methods can be quite tricky, so if you just want to test if your IoC setup works, your can implement MyUrlResolver like this:
public class MyUrlResolver : DefaultUrlResolver
    public MyUrlResolver(
        RouteCollection routes,
        IContentLoader contentLoader,
        ISiteDefinitionRepository siteDefinitionRepository,
        TemplateResolver templateResolver,
        IPermanentLinkMapper permanentLinkMapper,
        IContentLanguageSettingsHandler contentLanguageSettingsHandler)
        : base(
            routes,
            contentLoader,
            templateResolver,
Inject UrlResolver in your page controller and check if MyUrlResolver or DefaultUrlResolver is injected.
#173419
Dec 23, 2016 11:09
