SQL query to find database CMS version
In my local environment ,I have dozens of databases and I have different version of same site 7,8 and 9. Unfortunately the naming convention is not helping me to find the correct database. I am expecting a simple sql query which I could run againt the database and find the database version compatible to the CMS versions. Basically finding the available database I could link to the various version of CMS site I have
Any pointer?
#173497
Dec 29, 2016 12:29
The database version is returned by the dbo.sp_DatabaseVersion stored proc.
David
#173502
Dec 29, 2016 13:17
Executed the Stored Procedue sp_DatabaseVersion did not got any response in the query window.  However I could find the version of the database by reading the script for stored procedure. It did the trick for me.
Thanks David :)
#173507
Dec 30, 2016 6:59
Hi Amol,
As David said, you can execute sp_DatabaseVersion to get the database version:
declare @ver int
exec @ver=sp_DatabaseVersion
print @ver
Next, you can open packages/EPiServer.CMS.Core.X.X.X/tools/epiupdates/sql to find out which database version matches episerver assembly version.
For example:
db version 7036 is used for episerver.cms.core versions between 9.8.3 and 10.0.0, including 9.8.3.
episerver.cms.core 10.0.0 is using db version 7037, etc.
Hope this helps!
#173512
Dec 30, 2016 15:52
Thanks Dejan :) It Surely does help... Happy New Year
#173541
Jan 02, 2017 6:33
