Removing a job from 'Scheduled Jobs' list
Hello guys,
I created a job similar to a standard 'Remove Expired Carts' job but with additional functionality required for our project so, in fact, the new job should supersed the old one. Is there any convinient way to remove it from the job list? Two jobs with the similar names may look confusing..
Thank you.
#172745
Dec 09, 2016 17:08
Hi Nikolay! While you can't delete the scheduled job from Episerver (as it's built into the DLLs), you can certainly prevent the scheduled job from showing in Admin mode by using the Plug-In Manager. In Admin mode, click the Config tab, and find the Plug-in Manager link under the Tool Settings section. Click the "EPiServer.Business.Commerce" assembly name, then the Overview tab. Scroll down to Scheduled Job Administration, and uncheck the checkbox next to Remove Expired Carts. It should no longer appear in Admin mode.
#172752
Edited, Dec 10, 2016 6:26
Chris,
that's exactly what I needed. It is cool that no code changes required to disable standard jobs. Thanks a lot.
#172764
Dec 10, 2016 22:49
