Hi Marshall,
So, I assume you are talking about the built-in Episerver search? It is annoying that it doesn't index everything, but, I think that is on purpose becasue they want people to use Find. Anyway, here is what you do to index custom fields.
First, create an init module:
[InitializableModule]
public class SearchInitialization : IInitializableModule
IndexingService.DocumentAdding += CustomizeIndexing;
IndexingService.DocumentAdding -= CustomizeIndexing;
void CustomizeIndexing(object sender, EventArgs e)
var addUpdateEventArgs = e as AddUpdateEventArgs;
if(addUpdateEventArgs == null)
return; //Document is not being added/updated
var document = addUpdateEventArgs.Document;
var page = document.GetContent<IContent>() as PageData;
if(page != null && page is SitePageData)
var examplePage = page as SitePageData;
if(examplePage.YourCustomField != null)
document.Add(new Field("CUSTOM_FIELD", examplePage.YourCustomField, Field.Store.NO, Field.Index.ANALYZED));
Here is the extension method GetContent that the variable page is using when getting set:
public static class DocumentHelper
public static T GetContent<T>(this Document document) where T : IContent
const string fieldName = "EPISERVER_SEARCH_ID";
var fieldValue = document.Get(fieldName);
if(string.IsNullOrWhiteSpace(fieldValue))
throw new NotSupportedException(
string.Format("Specified document did not have a '{0}' field value", fieldName));
var fieldValueFragments = fieldValue.Split('|');
Guid contentGuid;
if(!Guid.TryParse(fieldValueFragments[0], out contentGuid))
"Expected first part of ID field to be valid GUID");
return ServiceLocator.Current.GetInstance<IContentLoader>().Get<T>(contentGuid);
Here is an example of a search query using the cutom field:
public void Search(string q)
var culture = ContentLanguage.PreferredCulture.Name;
SearchResult = new List<IndexResponseItem>();
var query = new GroupQuery(LuceneOperator.AND);
// Only search for pages
query.QueryExpressions.Add(new ContentQuery<PageData>());
// Search for keywords in any of te fields specified below (OR condition)
var keywordsQuery = new GroupQuery(LuceneOperator.OR);
// Search in default fields
keywordsQuery.QueryExpressions.Add(new FieldQuery(q));
// Search in the custom fields
keywordsQuery.QueryExpressions.Add(new CustomFieldQuery(q, "CUSTOM_FIELD"));
query.QueryExpressions.Add(keywordsQuery);
// The access control list query will remove any pages the user doesn't have read access to
var accessQuery = new AccessControlListQuery();
accessQuery.AddAclForUser(PrincipalInfo.Current, HttpContext.Current);
var fieldQueryResult = SearchHandler.Instance.GetSearchResults(query, 1, 40)
.IndexResponseItems
//.Where(x =>
// (x.Culture.Equals(culture) || string.IsNullOrEmpty(x.Culture))
.ToList();
SearchResult.AddRange(fieldQueryResult);
Lastly, when you update the field in your scheduled job, update the index:
var contentSearchHandler = ServiceLocator.Current.GetInstance<ContentSearchHandler>();
contentSearchHandler.UpdateItem(currentPage as IContent);
I hope this helps!
- John
Has anybody had any experience of the Episerver Search not indexing all the text fields in a page? I have a text field in my SitePageData which stubbonly refuses to show up in any searches. I have tried changing it to a XHTMLString to see if that makes any difference, but it does not. The field is updated from a scheduled task which collects all the text data from any blocks within the page. I know that the field is getting updated as the function that populates the fields can also read them out again to a log, with a different parameter.
The site is supposed to go live on 30th Dec so i am a bit worried
Thanks, in advance,
Marshall
