Homepage language as first segment
I have a website supporting multiple languages as translation of the pages. An example of a URL is www.websitedomain.com/en/somepage. Somehow the homepage doesn't have a language segment by default. The page can be reached under www.websitedomain.com/ and www.websitedomain.com/en/. I want to make a FriendlyUrlRewriteProvider that will rewrite the URL with the homepage language.
Is the FriendlyUrlRewriteProvider still the way to go in Episerver 9 or do I need another solution?
#172431
Dec 02, 2016 13:39
The default routing will use www.websitedomain.com/en/somepage (with language tag) for all language EXCEPT if you have set default culture on host. Hint: you do this in admin where you also specify site url and http/https.
If you have set this to "en" then language segment will be skipped on that host and you will get www.websitedomain.com/somepage for "en" language. Removing default culture on host will probably work?
#172432
Edited, Dec 02, 2016 14:18
I've not added a culture in the admin settings. The homepage is not using a language in the segment. Maybe its not a problem after all because a canonical is rendered in the homepage that is telling to index the www.websitedomain.com/en instead of www.websitedomain.com
#172434
Dec 02, 2016 16:07
If you render a canonical link you should be fine. It's actually better to just do that, otherwise you have to redirect users to e.g. /en/ which is way worse performance-wise.
#172443
Dec 02, 2016 17:54
Sounds fine then.
#172458
Dec 03, 2016 18:53
IIS URL Rewrite module can be used for redirection to avoid performance issues. (still an extra trip)
Cannonical URLs will be enough for SEO purposes.
Regards
/K
#172471
Dec 04, 2016 21:48
I was not referring to server performance though. It's annoying to be redirected when you're on your mobile or slow connection in general, when there's no need for it.
#172472
Dec 04, 2016 23:15
You can try to take a look at the description of "Strict language routing" that was introduced in version 7.5. See one of the last paragraphs of this page: http://world.episerver.com/blogs/Johan-Bjornfot/Dates1/2013/12/Routing-changes-in-75/
It contains a short description of language routing.
#172490
Dec 05, 2016 11:25
Thank you for the support. It is cleaner after all to just show the domain.
#172748
Dec 09, 2016 17:25
